Old 09-25-2016, 09:59 PM   #1
Shower in 33ik
Has anyone changed out their shower head in their cedar creek? Ours is just above a dribble when showering. Not sure if it is the pressure regulator or the shower head.
woodja72 is offline   Reply With Quote
Old 09-26-2016, 09:58 AM   #2
How's the water pressure on the kitchen and bathroom faucet? Have you checked the water pressure after taking the shower head off. If it looks good then check for debris clogging the shower head.
Old 09-26-2016, 10:16 AM   #3
It is a new trailer and it is an automatic regulator set at 45 psi. The water pressure in the kitchen is good as well as the bathroom sink. I haven't taken off the shower line to see but will check that out as well.
Old 09-26-2016, 11:28 AM   #4
dieselguy's Avatar
45 psi is a tad low ... most of us run our water pressure at @60 psi. Take the shower head off and run water thru the hose to see if it appears normal. There may be a check valve or screen in the shower head itself. We ditched the OEM shower head for an Oxygenics head ... lots better. Oxygenics Showerhead - 'Storm' Model - water saver - PPL Motor Homes
dieselguy is offline   Reply With Quote
Old 09-26-2016, 11:57 AM   #5
Appreciate it, will check it out. Would like more feedback from others about their psi settings
Old 09-26-2016, 12:12 PM   #6
CC38EL's Avatar
Our experiences point more to 'flow' than 'pressure'. We found that even with 60+ psi pressure, if we were using a 1/2" hose, we may still not get a good shower.
We use a Watts whole house regulator. It's 3/4" diameter and it's set to 50psi. We also changed over to 3/4" hose. And we removed the water restrictor that's in the head of the shower head.
If you can't get past your built in regulator, you might consider bigger hose diameter and removing that restrictor from your shower head.
Jim
Currently without a rig
CC38EL is offline   Reply With Quote
Old 09-26-2016, 01:54 PM   #7
ttanous's Avatar
I just use the regulator that has a pressure gauge on it and non adjustable. Set at 40 psi with 3/4" hose. Have not had any issues in my forty years of camping and I am not that old just started early.
ttanous is offline   Reply With Quote
Old 09-26-2016, 06:18 PM   #8
We are using 3/4" hose and a non adjustable regulator. Will check out the regulator in the shower head and see if it is setting we can take out
Old 09-27-2016, 12:50 PM   #9
markfromark's Avatar
We had the dealer install an Oxygenics(sp) shower head when we bought ours. DW has high expectations for the water pressure and she is satisfied with the water pressure in the shower now.
Mark and Dianna
along with Hank the Wonderdog
2016 CC Silverback 33IK
2015 Ram 3500 DRW
markfromark is offline   Reply With Quote
show, shower
