Old 03-21-2016, 09:03 AM   #1
Shower Quality
We currently own a 3055RL Bighorn and the shower is a one piece fiberglass unit. We notice that the showers in the Cedar Creek are two piece and the upper portion is a very thin material. My question is this? Do you have any trouble with the two piece showers. Are they durable? Do they leak?
Thank you in advance.
boomer116ars is online now   Reply With Quote
Old 03-21-2016, 10:06 AM   #2
dieselguy's Avatar
The only issue I ever had with the shower was in my SOB ... the pan cracked near the drain. It was a one piece. The shower in my stick house has 3 piece walls above the tub due to a remodel (one piece shower won't fit thru doorways in a finished home). They have not leaked in 5 years. No issues in my Silverback's shower enclosure.
dieselguy is offline   Reply With Quote
Old 03-23-2016, 05:58 PM   #3
Like you I once owned a heartland product with a single unit shower and I came to my senses and traded for a CC Silverback which has a 2 piece. I too was covered so after a few trips I went in the basement and did a bit of peeking around and never a hint of water. So I would say the overlap seal between the upper and lower is doing what it was designed to do. While I was down there also added a bit more spray foam around the drain area just add a bit off structural integrity.
hughd033 is offline   Reply With Quote
Old 03-24-2016, 07:27 PM   #4
JohnF's Avatar
2 piece in silverbacks, 1 piece in hathaways
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
quality, show, shower
