Old 06-30-2014, 09:16 PM   #1
Plain Old Member
Side Mount Faucet in Silverbacks
Not sure if I'd mentioned this before, but figured I'd post in case there are some newer Silverback owners with the side faucet on the master bath sink. Several months back in my venture to replace all of the faucets in this fifth wheel, I came across this small Moen faucet that swivels. Pretty much like a small version of a kitchen sink faucet. It's a shade more convenient as I can swivel it out of the way for things such as shaving. The pictures show it in the both positions. I opted to put a similar faucet to this in the kids bathroom, that does not swivel, since they tend to play with things and I figured I'd be asking for trouble. I've toyed with the idea of gutting the master bath countertop and making some major changes, but for now, this little faucet works well.
ID:	56841   Click image for larger version
Name:	Off Center.jpg
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-02-2014, 04:31 AM   #2
ret2006's Avatar
BigJohnD
When you replaced the faucets, did the Pex water lines lines match up to the Moen faucet without any alteration? DW wanted me to do this but I was afraid I would have to either shorten or lengthen the Pex and I didn't want to have to buy all the tools to do it.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 07-02-2014, 06:04 AM   #3
Plain Old Member
I'm about 99% sure they would have. The way they run into the basement, they did have some give up and down so you should be fine. On ours, I cut / installed stop valves, or shut off valves at each faucet when I made the swap.
Old 07-02-2014, 06:10 AM   #4
Plain Old Member
I usually buy all my supplies on eBay at
http://stores.ebay.com/Pex-Tubing-Store
Pretty much anything you ever need or want with pex and a lot cheaper than than lowes or HD. Not a bad investment should you ever decide to make a few changes, or have to make some repairs like I have. I've swapped our quite a few of the plastic fittings for brass as I feel like it.
Old 07-02-2014, 04:20 PM   #5
I changed ours out as well with longer-reach versions.. Certainly makes the sinks more user friendly. I went with a single-lever American Standard from Home Depot. As a bonus, they came with cable-actuated pop-up drains (only fit in the front sink though). The single lever setup required me to drill another hole, but it adds a touch of convenience for the side-sink design. Menard's has a half-turn shutoff valve that is 1/2" PEX to 3/8 MPT, so plumbing was snip, push, twist, done. The faucet had about 24" of hose out the bottom, so you'd have plenty of room to cut and recut the PEX if needed.
2014 Silverback 35QB4
2012 Ram 3500 6.7/slushbox
MIFarmer is offline   Reply With Quote
Old 07-03-2014, 07:56 AM   #6
BigjohnD
My DH also did the faucet change and we love it. Looking at your tile black splash, what did you on the top edge to Finish the edge? We have the tile and have already done the addition to the side of the stove and want to do behind the kitchen sink and the bath. The top edge of your tile looks really nice.
OHSLVRBK is offline   Reply With Quote
Old 07-03-2014, 10:20 PM   #7
Plain Old Member
All I did was mask it off and run a bead of Geocel Proflex. That stuff holds up well in just about any application. Did the same in the kitchen.
faucet, mount
