Old 09-28-2016, 01:37 PM   #11
wls
Originally Posted by httntheroad View Post
We came in at 12263 dry weight.added options were. Solar,dual pane windows,washer and dryer,trailair pinbox,slide topper,backup camera.belagio king bed.6 point level up.
if I had waited a bit longer when I ordered mine, last oct, I would have got the solar pkg.
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
wls is offline   Reply With Quote
Old 09-28-2016, 01:59 PM   #12
dieselguy's Avatar
wls ... you didn't miss anything buying when you did. The "solar" option is more of a marketing ploy. It may have the potential to charge a cell phone battery, but wouldn't cut it to maintain your house batteries should you have any major draw on them. 40 - 80 watts is a pretty weak charging system. Most solar installs I have seen are in the 300 - 400 watt plus setup.
dieselguy is offline   Reply With Quote
Old 09-28-2016, 03:22 PM   #13
Literature I got with unit says 200 watt.have ran for 12 hours.on residential fridge with batteries still showing full. (Direct sun)
httntheroad is offline   Reply With Quote
Old 09-28-2016, 04:49 PM   #14
I want to install solar on my Cedar Creek, I want to install four panels. My four six volt batteries will run my residential refrigerator for four days, just on battery power. I'm going to the factory next month and I want to see where the wire is ran.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 09-28-2016, 08:26 PM   #15
Do not think they did solar prep on your rig I maybe wrong .Check with forest river.angela is great!
Old 09-28-2016, 09:04 PM   #16
Cedar Creek did not prep my 15 Creek for solar, I just want to find out where I can run the cable. The factory is replacing my front cap
Old 09-28-2016, 09:24 PM   #17
While at the factory, if you see the new 34RL2, please take a few photos.
And goos luck with the new cap.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=12 | Booked=42
florabama is online now   Reply With Quote
Old 09-28-2016, 09:58 PM   #18
I plan to take right many photos, my black water tank has leaked since I brought the Creek. I want to learn how to change the valve
