Old 04-29-2015, 10:57 AM   #11
Confused...my fresh water tank drain is outside underneath the fresh water tank itself.
Those red/blue lines allow blow out existing water for storage or winterization.
Open them, pull anti freeze thru and then close them.
How would water get up and thru the system without using the water pump to pull it up and thru?
SilverbackMel is offline   Reply With Quote
Old 04-29-2015, 12:45 PM   #12
Re picture of convertor in storage area....Noticed that yours is located way back in RH corner....Mine is out front on right side....Does yours run hot or warm?????,,,,May move mine to make more room.......,J
Jim in Halifax is offline   Reply With Quote
Old 04-29-2015, 01:08 PM   #13
Oakman's Avatar
To be honest Jim, I've never checked to see if it is running hot. We're entering our 4th season with this trailer and haven't had any issues with it (knocking wood).
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-29-2015, 01:13 PM   #14
Oakman's Avatar
Now you have me confused Mel.
Hopefully this will clear up any confusion. The blue line and white line under your trailer is for the fresh water tank. The blue one is to drain the tank and the white one is the fresh water tank overflow. When filling your tank and water begins coming out the white hose, your tank is full.
Name:	IMG_6992 - Copy.JPG
The blue and red water lines in the storage compartment are the low point drains for the water lines in your tailer. I love having valves and not caps on these lines.
The red arrow in this picture points to the white tube used for drawing antifreeze into the water lines of the trailer during the winterization process.
Name:	SAM_2207 - Copy - Copy.JPG
Bob and Joyce
ATU Local 788
Old 04-30-2015, 07:29 AM   #15
Those are the drains. I added an extension to each and ball valves to make it easier to open and close. Factory install even had two different openings!
31RK 2014 Silverback
DrippingDuo
Chappy and Liz
Dripping Springs, TX
DrippingDuo is offline   Reply With Quote
Old 04-30-2015, 07:37 AM   #16
R&J Silverback's Avatar
I think mine just have caps on them. I will have to look and see if I also have valves inside.
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
drain
