Old 04-28-2015, 05:34 PM   #1
Silverback 29re low point drain
I have a 2015 silverback 29re and there are 2 pipes one blue one red (cold and hot water) pipes coming out of the bottom of the trailer by the front door. Where are the valves for these pipes, I have looked and can not find any
denville is offline   Reply With Quote
Old 04-28-2015, 05:43 PM   #2
kc8lvy's Avatar
In your side compartment there is a panel there that slides open. Mine is held by 1 screw.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 04-28-2015, 05:43 PM   #3
heavynlori's Avatar
Do they have caps on them and not a valve? Unscrew the cap....
heavynlori is offline   Reply With Quote
Old 04-28-2015, 05:47 PM   #4
Yes in the compartment with the sliding door. I could have sworn I looked there Thanks
Old 04-28-2015, 05:49 PM   #5
Oakman's Avatar
Mine has valves that open.
Picture of the passenger side storage with the panel closed.
And now with it open.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-28-2015, 05:51 PM   #6
That also means the blue and white one in the back of the trailer the p
Blue one has a valve is the drain for the fresh water tank.... I assume. ?????
Old 04-28-2015, 05:58 PM   #7
Oakman's Avatar
That would be correct.
Bob and Joyce
ATU Local 788
Old 04-28-2015, 06:16 PM   #8
Funny thing I also did not know I had a light until I saw your pictures
Old 04-28-2015, 06:22 PM   #9
Oakman's Avatar
That is funny because I didn't know I had a light in the front storage compartment for the longest time. Right after I installed a stick up light I finally noticed the factory installed one.
Bob and Joyce
ATU Local 788
Old 04-29-2015, 06:42 AM   #10
cpaulsen's Avatar
If you have caps on your low point drains....buy a couple of 1/2" ball valves.....makes it easier to drain!
cpaulsen is offline   Reply With Quote
drain
