Old 06-10-2015, 10:52 AM   #1
SilverBack 331K & need for slider hitch
Looking at the SilverBack 331K. Truck will be a F250 CC with the 6 3/4' bed. Looking at the front of the SilverBack, I am wondering if a slider hitch is required. Any info from someone with this setup would be appreciated.
segel10 is offline   Reply With Quote
Old 06-10-2015, 11:13 AM   #2
iceblaze580's Avatar
I would get one rather be safe than sorry
iceblaze580 is offline   Reply With Quote
Old 06-10-2015, 02:33 PM   #3
bigdaddy1
bigdaddy1's Avatar
I have a F350 CC that I use to tow my 3850RL Cardinal and I have the super glide hitch that is automatic slide. I love the way that it moves when I am backing or in a tight turn and I do not have to remember to get out and throw levers and such. It is not cheap but seems like everything we buy to camp and enjoy life is not cheap.
BigDaddy1
2015 F350 CC Lariat 4/4 SRW
6.7 diesel
2016 3850RL Cardinal
bigdaddy1 is offline   Reply With Quote
Old 06-10-2015, 02:37 PM   #4
TURBS's Avatar
I have one.
Need it yet ? Nope.
Will I ? Maybe!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-10-2015, 02:42 PM   #5
Oakman's Avatar
Although the corners of the front cap on the newer Silverbacks isn’t cut inward as dramatically as mine, I don’t think I’d bother buying a slider hitch. If you do decide to buy a slider I’d get a manual one because chances are you won’t use it very often.
BTW, I have a slider hitch because with my previous 2008 Wildcat I needed it. Since buying the Silverback in 2012 I have never used the slider.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-10-2015, 09:22 PM   #6
I have a Dodge 1 ton short wheelbase with a regular hitch for my 33IK only pulled it one time so far. You can turn that truck almost 90 degrees with no problem.
Gitiup is offline   Reply With Quote
Old 06-10-2015, 09:40 PM   #7
I was in your same predicament. I have a 2015 Ram SRW Mega Cab with 6' 4" bed. Trailer is Sandpiper 371REBH. No need for a slider. Turns 88 degrees. Looks like the tires are going to pull off the rims before I would have cab contact. If you need to turn that sharp you probably shouldn't be there.
jjvallee is offline   Reply With Quote
Old 06-11-2015, 07:47 AM   #8
5er_tom's Avatar
I would spend the extra few $100 and get a slider. That way you will never have to worry about it. Dark, cold, rainy night and you need to turn sharp and back into tight campsite. That would be when you might get in trouble without a slider.
Tom & Renťe
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 06-11-2015, 07:57 AM   #9
camper1999's Avatar
Originally Posted by Oakman View Post
Although the corners of the front cap on the newer Silverbacks isnít cut inward as dramatically as mine, I donít think Iíd bother buying a slider hitch. If you do decide to buy a slider Iíd get a manual one because chances are you wonít use it very often.
X2 especially the way the Silverback is designed. No matter what newer model brand of trailer everyone I have talked with that has at least a 6.5 foot bed never used or needed a slider. Most of mishap stories you will hear about has some extreme condition like backing up a steep grade or pushing the 90 degree radius a few more degrees. You will love the Silverback!
2011 GMC 2500HD Diesel
Old 06-11-2015, 01:47 PM   #10
2015 Silverback 33rl; 2008; 2500 Dodge short bed. Don't need it. Have it because of my previous 2011 Keystone cap design.
SilverbackMel is offline   Reply With Quote
hitch, slide
