Old 06-13-2016, 10:52 PM   #1
mbbutler's Avatar
Silverback 33ik kitchen sink water pressure
Any ideas? Can't find any linked pipes but I have much lower water pressure in kitchen sink compared to bathroom lavatory or shower. Any help appreciated.
2016 Cedar Creek Silverback 33IK
2008 Ford F-250 Crew Cab 4x4
mbbutler is offline   Reply With Quote
Old 06-14-2016, 07:39 AM   #2
dieselguy's Avatar
Just like in your stick house ... try removing the areator off the end of the faucet and checking for debris. Some have a reducer in the base of the pull out line that can be removed.
dieselguy is offline   Reply With Quote
Old 06-14-2016, 10:28 AM   #3
97flhtcui's Avatar
And like dieselguy said about the aerator, if it is not that, check the waterline that hooks up for your pull sprayer. It may have a one way valve on the end it hooks up to the faucet under the cabinet. My wife and I pull pieces of shale out of ours after we visit our daughters house in Phoenix. They have very hard water there.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 06-14-2016, 07:06 PM   #4
markfromark's Avatar
We had a problem with the water pressure in our kitchen sink as well. I adjusted the weight on the flexible water line that holds the sprayer in place and that solved the problem.The weight was kinking the hose a bit. Hope you find a simple solution.
Mark
Mark and Dianna
along with Hank the Wonderdog
2016 CC Silverback 33IK
2015 Ram 3500 DRW
markfromark is offline   Reply With Quote
Old 06-15-2016, 12:53 PM   #5
Canadian Full Timer
Question
Do you actually have a pull out sprayer like others are suggesting? I have the same issue in my kitchen sink, but have no sprayer. I have also pulled off that aerator thing but it made no difference. I still have stronger pressure in the shower/bathroom sink than in the kitchen sink.
Cherokeerose is offline   Reply With Quote
Old 06-15-2016, 03:03 PM   #6
dieselguy's Avatar
Any 33IK I've been in has the goose neck faucet with the intregal pull out spray head. Unless you have a kinked line (hard to fully examine without pulling down part of the belly pan) you may have a bad faucet cartrige. You might try removing the supply lines on the faucet from the PEX tubing and looking for anythng at that point to block flow.
Old 06-15-2016, 03:48 PM   #7
I have a 2016 33ik also, have the same issue. It's a kink in the line, when I pull my faucet out I get good pressure. Believe it can be fixed by moving the weight on the hose.
bpsanterre is offline   Reply With Quote
Old 06-15-2016, 07:29 PM   #8
Had a similar problem w/our 31rk. Cleaned the aerator and fixed the cold water but not the hot water.
DrippingDuo
Chappy and Liz
Dripping Springs, TX
DrippingDuo is offline   Reply With Quote
Old 06-16-2016, 09:10 PM   #9
mbbutler's Avatar
And the winner is:
Markfromark
Thank You!
Old 06-17-2016, 05:11 AM   #10
Your welcome... This forum has been a big help to me.
Mark and Dianna
2015 Ram 3500 DRW
pressure, sink, water
