Old 05-30-2012, 08:51 PM   #1
Silverback basement undercoat
Has anyone found the tin work in the basement to be sprayed with sticky undercoat instead of paint? What ever I store gets it all over.
Jscribner is offline   Reply With Quote
Old 05-30-2012, 09:16 PM   #2
B47
I can't say as i have, but I will check next time I go out to it.
Old 06-02-2012, 02:14 PM   #3
Oakman's Avatar
Mine is just painted. I wonder why an undercoating substance was applied to yours?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-02-2012, 05:07 PM   #4
It looks like thick paint. But when you leave anything on it, it sticks too it. The kids balls have to be cleaned with alcohol too get it off. The other thing with the basement is, in front of the battery you can see the ground. I used tin and foam too fill the hole. I'm not sure if they are all like that or not.
Old 06-02-2012, 05:18 PM   #5
B47
J - I just checked my 2012 29rk and all I have in the basement is the standard black flexible lining around the sides and no undercoating on either the compartment ceiling or floor. No holes either.
Did you buy the unit used or new? If used perhaps the previous owner did something? Take it to your dealer - its sounds like your basement is fairly useless to you in this condition.
Old 06-02-2012, 06:15 PM   #6
We bought it new in July it's a 2012 35qb4. It does look like paint but always tacky. Then the slide valve leaked while some of them turned off. The oil just dissolved the coating. Making bigger mess.
Old 06-05-2012, 09:15 AM   #7
Just paint
Checked ours - it is just painted - took the foam to it and sealed up all of the cracks/gaping holes!
2012 Cedar Creek Silverback 35QB4 "Silver Edition"
2011 Chev Silverado 3500HD Dually Duramax Turbo Diesel - Allison Trans / PullRite 20.5K Super 5th Wheel Hitch & SuperRails / Trailair Tri-Glide Air Ride Pin Box #21,000 / Honda 3000i Handi
mdamm is offline   Reply With Quote
Old 06-06-2012, 08:28 PM   #8
My 2012 is also tacky, but does not come off on my stuff yet.
Glenn
love to camp is offline   Reply With Quote
Old 06-07-2012, 06:54 PM   #9
Mine is like that as well. Sticky when hot but does not come off on stuff to bad for me yet.
Bigdog is offline   Reply With Quote
Old 06-10-2012, 08:14 PM   #10
The stuff sticks too the kids toys, my water hose and anything else I leave in their. You would think they would use something that would dry better.
