08-08-2016, 01:27 PM
Silverback bedroom TV Mount
Hello. I'm looking for a recommendation for a bedroom TV mount for our 2014 Silverback 33RL. The former owner took the TV and left part of the mount behind. It looks like it's attached to a piece of 3/8" lauan.
The TV weighs about 8.5# but it's 36" diagonally.
Has anyone found a good solution for the mount? Tilt and quick disconnect would be great!
2014 Cedar Creek Silverback 33RL
2008 Dodge 3500 6.7L Diesel, Quad Cab, 4x4, dually, long bed.
Steve & Pat, "Diesel" the Boxer, and "Molly" the Scotty
_______________
Bought camper 7/14/16
2016: 9 Nights camping
08-10-2016, 08:22 PM
A little confused as to your issue. My same rv ( 2015) built Oct 2014; tv rides just fine on the original bracket and pops right UP and OFF if need be.
Ours is aligned perfectly for viewing
from bed.
I would think most tv centers or Amazon can provide you with an alternative bracket.
Sounds like you have something in mind. Just remember that whatever you choose needs to absorb a lot of road abuse and needs to secure TIGHT!
08-16-2016, 04:27 PM
Thanks for your reply. I bought the camper used about a month ago. Among other things the previous owner kept the bedroom TV along with the parts of the mount that is screwed into the back of the TV. All I am trying to do is to get a quick disconnect mount for a 32" Samsung TV (VESA 200x200) that will work.
I expect to take the TV down during travel so I need something to make removal and re installation of the TV easy.
This is what I have to work with
What do you think?
Thanks!
_______________
08-16-2016, 04:35 PM
Looks like mine. Should be " universal" mount plate for the tv. Available at places that sell TV's or Amazon. Just measure your existing bracket holes. Just drops right in and believe it or not 😁 it HOLDS!!
08-16-2016, 04:37 PM
So, all I do is to remove the aluminum components and connect the new mount?
_______________
08-16-2016, 07:20 PM
Hopefully this posts. I have a 27 inch Jensen. It has 4 screws that mount into the rear of the tv and they are 4 inches spread ( upper to lower ) The tv simply mounts in the brackets by inserting and securing by pulling down.
Hope this helps!
08-16-2016, 07:32 PM
Tv mount
You may need a variation in bracket mounting to FIT your 32 inch back plate of your tv. Basically these are STANDARD mounts.
Second; take off is 10 seconds. Re install 20 seconds. Off; simply pressure by Palm hit upwards on each side ( from bottom corners) and bingo.
Re install same only ( reversed) you want to ensure secured into bracket because you do not want it to jump when traveling on a rough road
