Old 11-29-2014, 01:52 PM   #1
Silverback brochure and Silverback, CC differences
Is there a better brochure on the Silverback's than that little one page thing on the Cedar Creek/Silverback website?
Also what construction differences are there between the Silverback and Cedar Creek?
'15 Columbus 295RL
2015 Ford F350 with 6.7 PSD
2014: camped 12 nights
johndeerefarmer is offline   Reply With Quote
Old 11-29-2014, 02:18 PM   #2
Differences? Mostly what is offered as options on SB is standard on CC. There is also interior color schemes and floor plan differences. IMHO you cant go wrong with either.
donniedu is offline   Reply With Quote
Old 11-29-2014, 02:18 PM   #3
I just bought a new silverback 29RE I believe the differences are mainly the base options. you can option out a silverback if you wish but price creeps up to that of the cedar creek then. Also the cedar creek has a moulded rear cap and the silverback doesnt.
thor is offline   Reply With Quote
Old 11-29-2014, 02:20 PM   #4
I'll answer from my perspective as a Cedar Creek owner. Construction is basically the same, they come off the same assembly line. CC is a bit more upscale, but also runs a little higher in price. Also the CCs may have a bit more insulation on board. However, I can't swear to that. CCs may have more available options than the SBs. Others may have other perspectives.
As for the brochures, I think online is the only source (only one I ever found). If getting to the factory in northern Indiana is not in the cards, I'd suggest looking for a large RV show near you.
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
WeRCreekers is offline   Reply With Quote
Old 11-29-2014, 02:36 PM   #5
Thanks. I was wondering if there are any structural differences between the two? I had read somewhere that the CC had a dropped frame and bigger basement vs a straight frame and smaller basement. I don't remember if I read that over on rv.net or here awhile back.
'15 Columbus 295RL
Old 11-29-2014, 03:37 PM   #6
R&J Silverback's Avatar
might check out u tube on the construction of the units. both are great and I think they are the best constructed units on the market. Biggest thing is what floor plan works for you.
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
Old 11-29-2014, 03:53 PM   #7
Yes the CC has a drop frame "Z frame " they all it. So the basement floor is lower and no step. The SB is a straight frame so the basement floor is higher with a step.
SB has 3 steps for the entry the CC 4 steps that are aluminum. Both have Dirt Devil central vans but the CC has the dust pan opening by the steps. SB has amore sculptured front cap for tighter turns. Slide control knobs are different.
All CC are now 7000lb axles and the CC has adjustable shackles. SB is a 6000 lb axle.
Other differences I recall have been covered. We have a multi page SB brochure but the CC is a one pager for now.
There is a difference in the cabinets between the 2. Maple on the SB and the CC just switched to new wood. I think it was beech.
We just spent 3 weeks of looking hard at these 5ers.
2 for the road is offline   Reply With Quote
Old 11-29-2014, 08:00 PM   #8
Video might help:
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 11-30-2014, 12:34 PM   #9
Thanks for the responses
'15 Columbus 295RL
Old 12-02-2014, 05:17 PM   #10
My SB 37BH has 7k axels not 6k, suspension is the same. The CC has a better air system with cold air returns in the roof not at the actual AC unit like the SB use. The rear cap is molded and finish has more options. For example the window shades are power. The same basic build process is used for both.
SKGCRD is offline   Reply With Quote
Old 12-02-2014, 08:20 PM   #11
Are return air vents a big advantage if you have two a/c's? I see how it would make a difference with only one
'15 Columbus 295RL
Old 12-03-2014, 10:22 AM   #12
My coach has two air units to which both are connected to the roof ducts. My second unit is located in front master bedroom. I have never owned a CC with the return air vents but it appears that system is less noisy and could be a little more comfortable from a more uniform climate control perspective. I can't confirm this but it seems plausible.
Old 12-14-2014, 08:57 AM   #13
Oakman's Avatar
If you have a Facebook account you can go to the Cedar Creek Fifth Wheels Facebook page and scroll down to the latest Silverback Brochure. I don't know why that one isn't available for download on the CC Silverback website.
Bob and Joyce
2013 CC Silverback 29RL
ATU Local 788
Oakman is offline   Reply With Quote
Old 12-14-2014, 12:55 PM   #14
If you would like a printed copy of the Silverback brochure and the Cedar Creek "Back to Basics" a guide to Cedar Creek Construction, pm me and I would be happy to mail it to you. We are through with or copy now that we bought a 29RE. The Silverback one is a 6 page foldout.
