Old 12-17-2014, 07:58 PM   #11
We have a 2014 29RE Silverback....towing with a 2014 Chev 2500HD short box with Reese R16 hitch with slider......Been at 90* once...no problems.....Slider not used!!!! J
Jim in Halifax is offline   Reply With Quote
Old 12-17-2014, 09:51 PM   #12
camper1999's Avatar
Originally Posted by Duckogram View Post
JDFarmer,
The responses you received for your questions numbered 1 and 3 are not as accurate as they seem to be.
1. You can tow with a short bed without a slider. You just will not have the ability to make turns much over 70 some odd degrees without hitting the cab.
3. Here is the reference from Lippert Components: https://lci1.com/goose-box
I believe the model in question comes with the Lippert 1621 pin box.
FR does not warranty the frame and has no say in it. LCI does. The notion that you would totally void your warranty is rejected (although they didn't exactly say that). If you are interested in the truth, I suggest you contact LCI directly.
FYI, I was the recipient of false info from a FR Warranty/Service Mgr not long ago. A visit to the factory straightened that out. The good news is that person is no longer a FR employee and my issue was satisfactorily resolved.
Your point number 1 is untrue. I have a 6.5 short bed and have been at a 90 degree backing in, no slider, and plenty of room between the cab and trailer
2011 GMC 2500HD Diesel
Old 12-18-2014, 04:48 AM   #13
Former Full Timer
Duckogram's Avatar
Your response may be true for your TV. The OP has a Ford and I had a 2010 CC SB with a non sliding hitch. My turn radius was a hair over 80*. Of course, it is possible that the Silverback nose cap is or was shaped differently. There are other variables as well.
Then there is the fact that we agree that you CAN tow with a SB sans slider. That was the point after all.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 12-18-2014, 08:05 AM   #14
Sliders Reuired???????
I guess I should clarify my statement re sliders...." It all depends on the design construction of the 5th wheel front end.....Newer ones are designed to be able to be at 90* with the towing vehicle...i.e. the CC 29RE....J
