Old 02-03-2015, 11:41 PM   #11
Have a 2014 31RK and when the weather improves will have to check out the roof. Thanks for the update on this problem.
Silverback Iowan is offline   Reply With Quote
Old 02-04-2015, 09:00 AM   #12
silverback1's Avatar
We had a 2013 Silverback that went back to the factory for suspected frame issue-turned out frame was okay. Anyway I turned in a list as per dealer instructions on any other problems. Turned out to be a huge list. One of my main concerns was the shoddy rubber roof installation. Gaps in the roof plywood with some pieces sticking up 1/8 in or more-staples poking up all over and wrinkles in the rubber roof membrane. The bedroom slide roof was so bad I had to sweep it off or it would dump a gallon or more of water inside when we retracted the bedroom slide! Unfortunately the factory said it looked good to them. This was our 3rd 5th wheel so I am not a newbie. That cost them a customer. We just took delivery of a Columbus 29RL and the quality of fit and finish are excellent. Good luck with your problems !
silverback1 is offline   Reply With Quote
roo, roof
