Old 07-11-2015, 09:01 AM   #1
traeger3's Avatar
Silverback slides will not work off battery powe
We have had friends and family helping us to figure out why the slides do not work from battery power. Everything works from shore power, but we want to dry camp in the Smokies. Stabilizer jacks don't work either. Our silverback is a 2013 29RE. Any suggestions?
traeger3 is online now   Reply With Quote
Old 07-11-2015, 10:05 AM   #2
fonzie's Avatar
Look for fuse or mini-breaker near battery, replace fuse if burnt or re-set mini-breaker by pressing small black button......hope that is it.
Fonzie
Old 07-11-2015, 10:25 AM   #3
traeger3's Avatar
Can't find this fuse. Checked breaker it is fine. Could the fuse have fallen off? Would it be located on the breaker panel?
Old 07-11-2015, 10:34 AM   #4
VinceU's Avatar
Is this an hydraulic pump application where same pump is for slides and jacks? If so circuit protector located between battery and pump skid, closer to battery
Old 07-11-2015, 10:40 AM   #5
traeger3's Avatar
No, jacks are separate.
Old 07-11-2015, 10:41 AM   #6
traeger3's Avatar
I can't find that fuse anywhere.does that breaker/fuse go on the panel. I can't find it. I have spares in the campe, but don't have any idea were it was supposed to be mounted.
Old 07-11-2015, 11:36 AM   #7
dieselguy's Avatar
Have you checked the battery disconnect switch in the convience center?
dieselguy is online now   Reply With Quote
Old 07-11-2015, 11:45 AM   #8
Dead or disconnected battery
Harkerr is offline   Reply With Quote
Old 07-11-2015, 11:47 AM   #9
Send a message via Yahoo to Magee
In my older Cardinal a fuse that looks like that is "hidden" under a heavy rubber flap, which is in the front storage compartment. I also have found that using only one battery does not supply enough power to work the slides or front jacks.
Magee
Magee is offline   Reply With Quote
Old 07-11-2015, 11:52 AM   #10
dieselguy's Avatar
Quote
"I also have found that using only one battery does not supply enough power to work the slides or front jacks."
Must have been a bad battery ... thousands of us use one battery to operate slides and landing gear without issue other than an occasional bad resettable breaker.
battery, slide, slide out
