Old 12-28-2015, 05:37 PM   #11
dieselguy's Avatar
I forget I deal in hyd troubleshooting quite often at work ... they basically want you to close the slides, remove the extend hose (one opposite the silver ram) from the cylinder and cap it, then press the retract button. If you see a steady flow of oil out the ftg when you are pressing the retract button ... you have a leaking piston seal. About a half dozen drops is normal.
dieselguy is offline   Reply With Quote
Old 12-28-2015, 07:10 PM   #12
Thx Dieselguy. If I continue to have problem I will check that out. It is under warranty so I might take it to my dealer. They are good...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
slide
