Old 06-26-2016, 02:02 PM   #1
Slide issue
We have a 2014 Cedar Creek 36CKTS. Parked it a month ago, went out today to get ready for a trip next week. Ran the slides out and did some work. Went to put the slides back in, and the dining slide only the back starts to come in, which angles the slide. I stopped and tried several times with the same result. The side by the door does not move. Nothing appears to be blocking it. Any suggestions?
2013 F350, 4x4,6.7 diesel,CC, DRW 3.73 rear
B&W companion hitch
kautzmank is offline   Reply With Quote
Old 06-26-2016, 03:28 PM   #2
Hutch333id's Avatar
If these are hydraulic slides try resetting the little circuit breaker trip switch. They sometimes trip if there has been a dip in the voltage. Unfortunately, I don't have a photo to show you but if you follow the red cable from the hydraulic pump to where it is wired in to the connectors at the wall (basement) there are some very small buttons on the top of the connector. Make sure these a pressed down. That may help. If it is an electric slide look for the manual override box in the basement area and work on that.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 06-26-2016, 07:48 PM   #3
You may have broken a gear in the synchronization assembly underneath. It happens often when the tube crowns. Lippert has a simple fix for the crowning with a washer. You still have to replace the gear.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 06-26-2016, 08:14 PM   #4
Where would the gear be located? Don't suppose that is something I could do in the next 2 days.
B&W companion hitch
Old 06-26-2016, 10:00 PM   #5
If it's a broken gear you have to get it from Lippert. Not in 2 days. Check under the slide to be sure what's broken. I have also just worked the slide in, braced it, gone camping and not extended it.
William & Sara
Old 06-27-2016, 02:32 PM   #6
Okay, 1st issue is resolved. The drive side of the slide, the gear had moved off the teeth of the sync bar. Got that fixed (still need a minor adjustment), and that slide came in. As soon as that was in, I lost ALL hydraulics. So I still have the kitchen slide out, with NO hydraulics at all.
B&W companion hitch
Old 06-27-2016, 03:03 PM   #7
If there is no sound from the motor, I would look at the breakers (located behind the plastic pull away barrier on the right side of front basement. You may have one tripped. If so, I wonder if the misaligned slide has overtaxed the hydraulics?? You may want to manually shut it off (from in the water bay. I think its the valve labeled "main".
Doug & Cindy
2014 36 CKTS: Titan Disc Brakes, EMS, Trav'lr, 20k GooseBox
2016 Ram 3500 CTD 4x4 CCLB DRW, Laramie, Factory Rear Air Suspension, 3.73
DJNCJ is offline   Reply With Quote
Old 06-27-2016, 04:34 PM   #8
junebug39's Avatar
Did you try the reset buttons on the slides?
junebug39 is offline   Reply With Quote
slide
