Old 11-23-2015, 11:17 PM   #31
Originally Posted by Stroker 06 View Post
Other slides go in fine,but have noticed they are going in slower this time around. Lights dim, pump makes a clicking sound.
Sounds like you may have a battery issue. Is the slide that is not coming in the largest slide on your RV? Could be you just don't have the power to handle the load? Try jumping the battery or changing it out..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 11-23-2015, 11:19 PM   #32
97flhtcui's Avatar
If you are plugged into shore power, is you battery disconnect switch on or off? Your slides won't work right on shore power only.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 11-23-2015, 11:19 PM   #33
According to instrument panel, battery showing full charge, had converter replaced few years back.Not sure how accurate this reading is without testing battery.
Stroker 06 is offline   Reply With Quote
Old 11-23-2015, 11:24 PM   #34
Battery disconnect switch is on position. I remember a few years back lights dimmed under a load, replaced converter all was good. It as during summer when we ran ac, lights, etc.
Old 11-23-2015, 11:25 PM   #35
97flhtcui's Avatar
If your battery disconnect is switched to disconnect, the instrument panel battery meter will read converter 12v only. Not enough power to operate slides.
MORryde IS 7000 LB
Kodiak Disc Brakes
Old 11-23-2015, 11:26 PM   #36
Last slide to go in is the big slide. Slide in bedroom goes in first, then two living room slides which are the same size.
Old 11-23-2015, 11:27 PM   #37
Stoker, Try this.. Push the battery test button and at the same time push the slide button.. See what the battery level LEDs do. When you check it static there is no load and I'm not sure how accurate they are anyway.
If the LEDs drop down significantly then your battery voltage is dropping due to a load issue and you just don't have the juice ( current) from the battery you need..
2016 Siverback 33IK
Old 11-23-2015, 11:31 PM   #38
Stoker, Lets just review where we are or where I think you are..
Shore power connected...
50 amp shore power breaker on...
Battery disconnect switch in compartment on...
New or not to old battery...
It just concerns me that your lights dim and the pump clucks.. Reminds me of trying to turn a starter over in a car with a bad or weak battery..
2016 Siverback 33IK
Old 11-23-2015, 11:33 PM   #39
One more thing.. Check the connection to your battery posts.. Make sure they are tight and clean... Sorry if I'm being a pest but I'd like to get you closed up and sometime we overlook the simple things..
2016 Siverback 33IK
Old 11-23-2015, 11:35 PM   #40
Rite, everything u listed a go. The lights is what makes me think a battery issue as well. Just out of curiosity, what is average life span for a battery. My unit is 6 years old, and has been stationary. Minus the factory battery, thus is the first one I've replaced
slide
