Old 11-24-2015, 03:04 PM   #61
Thank you!
Stroker 06 is offline   Reply With Quote
Old 11-24-2015, 03:18 PM   #62
Pickin' & Campin'
Yes the gauges are next to worthless especially when it comes to the battery. And even more especially, a deep cycle battery.
The gauge indicates nothing more than static voltage. That voltage can show full bars even on a battery not up to snuff. It has no way of measuring voltage under load which is how a battery has to be tested. A deep cycle battery will show good static voltage throughout at least 2/3 of its discharge.
On of the earlier posters mentioned pushing the battery test button while operating the slides. That was excellent advice. Load the battery by using the slide pump motor and I'll bet the bars don't indicate full.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 11-24-2015, 04:25 PM   #63
Thanks again for all the advice folks. Will do as suggested. Hope n pray it's just battery. Have a good holiday to all the fellow rver's! Let's take a moment to reflect on those who can't be home for the holidays,and to the families whose loved ones who won't make it home. Thank you and God bless!
Old 11-27-2015, 08:31 PM   #64
Just got back from buttoning up rv. Battery was dead as a door nail. Did battery load pump test, went from reading fully charged to nothing. Put new battery in and brought in remaining slide..Just want to say thank you to all who helped me. It was depressing to come back to the city, but least I got something to look forward to.
Old 11-27-2015, 09:28 PM   #65
Glad to hear...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 11-27-2015, 09:36 PM   #66
Ditto..👌👍
Old 11-27-2015, 10:19 PM   #67
Good news. Now you don't have to worry about what is wrong with it all Winter.
GOTTOYS is offline   Reply With Quote
Old 11-27-2015, 10:21 PM   #68
And I learned a lot from you guys. Thank you.
Old 11-27-2015, 10:31 PM   #69
caper's Avatar
According to instrument panel, battery showing full charge,
The panel will show a full charge battery when on shore power even if the battery is dead of not there.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 11-27-2015, 10:36 PM   #70
Yeah, it showed full charge, then I hit battery indicator and pump switch on slide, nothing led lights wasn't registering anything .
slide
