Old 07-24-2016, 06:17 PM   #1
Slide marked lino
Our slide must have somehow got a small rock under it and has created a good scratch in our new trailer floor. Anyone have a repair suggestion. Looks like vinyl plank but believe it's lino.
Doug Currie is offline   Reply With Quote
Old 07-24-2016, 07:14 PM   #2
You may want to check for and screws or bolts that may have come through the slide floor and caused the damage.
2004 silverado 2500HD ext cab short bed
2012 Rockwood 8280WS
Herms1960 is offline   Reply With Quote
Old 07-24-2016, 08:50 PM   #3
Seasoned Rookie
Lefty59's Avatar
We've now had the same thing happen 3 times in our Wildcat. A small stone somehow gets under the edge of the slide and then when the slide goes out it gouges the vinyl plank flooring. We've tried filling the gouge with wax by rubbing a candle across the floor and then coloring the patch with a crayon, but it doesn't seem to work very well. I think we are going to try melting a brown crayon and pour it directly into the gouges and see if that works.
We now put a piece of foam across the entire length of the slide once it is retracted to try and keep any rocks from finding their way under it. So far, no more gouges have occurred but we fear it may just be a matter of time.
Best of luck to you and please let us know if you find a solution.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
slide
