Old 03-05-2014, 07:09 PM   #1
Slide-out Alignment
We purchased our 2014 36CKTS in late October and drove it to Florida for the month of November and had a wonderful time. The trailer pulls extremely well (Ford 250 diesel longbox). The only major problem was the foot valve on the Dometic toilet blew up so we dried camped for 3 days until it was replaced. (I will be carrying a spare in the future.
My concern is the left-side slide-out (door side) does not seem to be squared properly in the opening. There is less space between the slide-out and trailer wall on one side compared to the other, so much so that the outer weather stripping is not making full contact with the slide-out on one side.
Has any one else had this issue?
FYI
This is a list of the warranty issues
Kitchen
Stove Top Grill- chipped
Chair- chip on rail
Night Blind at Front Door defective
Floor- cut 3" into dark square by table and by vent
Kitchen Tap- noisy
Dometic Fridge fan- noisy and constant
Living Room
Right Drawer off square-won't stay shut during travel
Couch-wire under fold out bed fell off
Bathroom
Toilet Valve Crack-replaced
Shower-collects a lot of water- tilted forward
Bedroom
Closet door- not lined up on right side to slide into grove
Electrical wires under bed get caught when slide goes out
Window clip (closet side) defective
Outside
Propane Compartment- trim fell off
Cap- scratch on left side facing cap
Screen Door- 2 cracks/lock not lined up
Front Compartment-key latch does not touch frame and cannot be locked
MarkSkinner is offline   Reply With Quote
Old 03-05-2014, 07:13 PM   #2
Ford Idaho's Avatar
Good night Lucy!
Old 03-05-2014, 07:31 PM   #3
Sewhappy's Avatar
Gosh, what a list! Sorry. For what they cost, you expect better quality. Are these all things that happened after you picked it up or is this your list from your walk through? I am going to copy your list and check these things when we pick our CC 36ckts up.
Sewhappy is offline   Reply With Quote
Old 03-05-2014, 07:35 PM   #4
bubbles's Avatar
If your saying that one end of your slide is not fully retracting or not fully extending and you have a Lippert system the adjustements are made via 3 hex nuts on the hydraulic actuators. 2 nuts control the extend and 1 nut controls the retract. 2 actuators are used (1 on each end of the slide room). It's a very easy adjustment once gaining access to the actuator. Of course, if you don't have a lippert system?
Old 03-05-2014, 07:53 PM   #5
bubbles's Avatar
This might help? Basicly, the 2 nuts adjust the out and the 1 self locking nut adjusts the in.
Old 03-05-2014, 08:12 PM   #6
Platokidd's Avatar
Dometic Fridge fan are noisy mine is too.
Living Room could be a easy fix
Shower-collects a lot of water- tilted forward.. Level / dont tilt
Bedroom...Again adjustments can be made. Wires need addressed. Here again should be a simple fix.
Propane Compartment- trim fell off--
Cap- scratch on left side facing cap--- that sucks can you wax it out?
Screen Door- 2 cracks/lock not lined up--- cracks?? new door?
Front Compartment-key latch does not touch frame and cannot be locked. adjustment could fix that.
Have slide adjusted, I too had this issue.
Sounds like most of the flaws can be fixed without to much of a problem. Hope you were not expecting near perfect. This is typical or the norm
Welcome to today's world of rving.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 03-05-2014, 08:45 PM   #7
Brother Les's Avatar
Give your dealer a call and have the list ready when you take it back.
Calling my dealer tomorrow because of a slide issue and will take it back on Sat.
Brother Les
Old 03-05-2014, 09:19 PM   #8
Plain Old Member
Easy to adjust with a little help from someone. Wipers obviously need to touch all the way around. Ours is not perfect by no means, but it works, and doesn't leak. I thought about adjusting a few of ours, until I looked close at some of the clearances inside. Slide fascia dodges a few things by 1/8" on the living room slide. Figured I'd leave well enough alone.
On the rest of the list, none of it is a shocker. I've fixed about that many items on ours, and let the dealer fix some of the more major items. After the last few motorhomes, I'm used to fixing crap. When buying now, I just expect the worst, and hope for the best. Seems every one we've owned after our last Sunnybrook product (Pre-Winnebago Ind), has had it's share of issues. Guess we had beginners luck with the first 4 as they didn't have hardly any issues at all. Near perfect. Just not the way it is any more.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 03-06-2014, 05:57 AM   #9
Sewhappy's Avatar
We will definitely lower our expectations when we pick up our CC 36ckts. The factory is very busy right now. We were told 8 to 10 weeks. So they could really be rushing to get them out the door.
Old 03-06-2014, 08:24 AM   #10
mtcreeker's Avatar
We have owned 4 Cedar Creeks and none had the list of issues you have. Our present 2013 CKTS is the best so far. Little things come up but I've fixed most myself. I've heard and witnessed horror stories about other brands and some very high end units. Your dealer should fix/repair your issues.
Steve & Carol
2013 Custom 36 CKTS Cedar Creek
mtcreeker is offline   Reply With Quote
alignment, slide, slide out
