Old 09-22-2014, 05:35 PM   #1
slide out override
I have a Cedar Creek 34RLSA with 3 slides. There are three options on the panel that are knobs. One says main slide and one says opposite slide and the other says bedroom slide. Does anyone know if these knobs allow to bring in the slides in independently of one another. When you push the slide button inside all Three either come in or go out starting with the bedroom first. Thanks
Arc of the Sun is offline   Reply With Quote
Old 09-22-2014, 06:17 PM   #2
MC9
When you turn off a knob that slide doesn't move (clockwise til it stops).
MC9 is offline   Reply With Quote
Old 09-22-2014, 07:04 PM   #3
We use the valves all the time...
1. Open three slides and pack for a trip. Once the clothes are loaded we then shut off the main slide, and close up the bedroom (front living room).
2. We keep the slides closed most of the time, and will open just the kitchen slide if we are just working around the front/kitchen.
3. When leaving a campground, the DW will finish in the back and let me know, I will shut the main slide off and she will draw close the bedroom slides.
Works great - Keep in mind these are valves and you need to close them all the way, not just stop aligned with the word closed. You need to close them all the way around, almost 3/4 of a turn.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 09-22-2014, 09:14 PM   #4
Duckogram's Avatar
x2 for what Walter said.
Also, if a knob comes loose there is a hex head set screw to tighten it up however the screws are too short and only grab the last 2 threads in the plastic knob.
The fix is a longer set screw. CC has known this for a couple of years so they probably have not fixed it yet..
ILB ( | )
Old 09-23-2014, 11:15 AM   #5
Thank you
slide, slide out
