Old 07-31-2014, 01:10 PM   #1
Slideout beaker tripped
Hello Fellow RV'ers,
My 2014 Silverback 31RK just popped one of the breakers for the slides. We have had the unit since May, cycled the slides in and out at least a dozen times and have had no slide issues. The slides were in for the last 3 weeks and I extended them today to check the inside. I had to plug in the RV since the battery was dead - need to remember to throw the battery disconnect going forward. After verifying that all was OK, I retracted the slides. The bedroom slide and the dinette slide came in OK but the living room slide only came in about half way. After reading about slide breakers for 10 minutes, I reset the tripped one and the slide came in the rest of the way.
This is our first RV with slides so I am kinda like a new parent. Not sure if a trip to the ER is needed or just calm down, drink a beer and be happy it was an easy fix.
Thoughts anyone?
Thanks,
Ken
birdman77 is offline   Reply With Quote
Old 07-31-2014, 01:21 PM   #2
At my PDI, the dude told me not to bring in (or out) all 3 slides without letting the system rest for about 10 seconds along the way. So I bring in the bedroom slide, pause 10 sec, then bring in a living room slide, pause 10 sec, then finish. Same thing when I put the slides out. The maintenance guy said the breaker can overheat and trip if you do them all without pausing.
I don't think you have anything wrong. Just try this procedure for a while and see if it doesn't fix your "problem."
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 08-01-2014, 01:02 AM   #3
Plain Old Member
Geez. We bring in all 4 slides without stopping, then the level up jacks. Never had an issues with anything tripping in 8 months now. Now that it's mentioned, it'll probably trip next time I bring them in.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-01-2014, 04:07 AM   #4
Witch Doctor's Avatar
Thoughts anyone?
Thanks,
Ken
Ken, Where did you find the breaker that tripped? For your sides and where all the slides ran through that breaker?.......
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 08-01-2014, 04:16 AM   #5
Plain Old Member
Should be in the front storage. 1 hydraulic pump runs all slides and level up system on the silverbacks.
Old 08-01-2014, 05:23 AM   #6
The breakers are accessed through the front storage compartment. On the right there is a cover that can be opened with a label on it, "slide mini breakers". Open this door and on the back wall are 3 breakers, one for each slide. There is a spot for a fourth and I assume if I had auto leveling, that would be populated. I can take a picture today if that would help.
Ken
Old 08-01-2014, 05:53 AM   #7
Plain Old Member
I haven't looked close at ours, but trying to figure out why you would have 3 breakers for 3 slides that are all run off of one pump, one solenoid, one switch? Common hydraulics running to all 3 slides, least resistence goes out first followed by the others. If it were 3 slides on 3 different switches, I'd say ok.
A picture would be nice.
Old 08-01-2014, 06:03 AM   #8
Rrickim63's Avatar
With the battery low, the converter may have been using most of its available current to recharge battery. If battery is low again, i would let it charge the battery for a little while before moving slides.
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 08-04-2014, 09:53 AM   #9
browniac's Avatar
A picture would definitely be appreciated. My 36ckts is setting stranded right now unable to bring the slide outs in and I feel that it is due to these breakers being tripped. I am not sure where to look in the compartment and of course Lippert is closed on the weekends, go figure, when most rv'ers are out and about.
browniac is offline   Reply With Quote
Old 08-04-2014, 10:06 AM   #10
Plain Old Member
Look in the very front / storage basement under the fifth wheel overhang. If you open the cargo door and are look in, look towards the right / driver's side. There are numerous wires and resettable breakers in that area near the level up / slide out pump. Ours has a panel covering these which is easy to move out of the way.
Old 08-04-2014, 10:06 AM   #11
Plain Old Member
browniac, just seen that was your first post. Welcome to the forum my friend. Glad to have you here.
Old 08-04-2014, 10:14 AM   #12
browniac's Avatar
Thanks! I was able to get to the access panel where the mini breakers are but my problem is I don't know what I'm looking for when it comes to mini breakers.
Old 08-04-2014, 10:20 AM   #13
Plain Old Member
I'm not exactly sure how the Cedar Creek's look, but I think it's a resettable breaker. The ones I'm familiar with are tiny gray colored squares with a tiny black reset button on the side. To be honest I haven't studied mine hard enough yet, and I'm not home to take a picture of it.
Old 08-04-2014, 10:33 AM   #14
browniac's Avatar
That helps a lot just knowing more about what to look for. From what I can gather there is no reference to these in any of the documentation or owners manuals. I will be getting back to the coach this weekend. Had to get back to reality so the wife could go back to work. Luckily we were only about a hundred miles from home and the campground owner said we could leave it disconnected for $3 a day!! Thanks for the assistance!! Being retired Army, I'm use to things breaking and not having mfg support lol. I was a M777 Howitzer platoon sgt and we were use to technical difficulties!!
Old 08-04-2014, 10:39 AM   #15
Plain Old Member
You've got me curious enough now, so when I get home Wednesday, I'll be looking myself. May post a few pictures just for comparison of the Silverback to the Cedar Creek. I've just glanced at ours, but hadn't really disected everything. You're correct on the documentation. I've only owned one that actually had detailed electrical and plumbing drawings, and it wasn't built by Forest River.
On another note, thank you for your service in the Army!
Old 08-04-2014, 12:39 PM   #16
I hope the attached pictures help....
ID:	59671   Click image for larger version
ID:	59672   Click image for larger version
ID:	59673   Click image for larger version
Old 08-05-2014, 12:17 AM   #17
Plain Old Member
That's what mine looks like. Thanks for those pictures birdman. Hopefully browniacs looks similar and it'll help him get it rolling again.
Old 08-05-2014, 12:44 AM   #18
ready2retire's Avatar
After a 3 week rest, none of the 3 slide outs work. Not even a click. All other utilities works fine. Battery ( 2 x in parallel) fully charged. Tried to locate in-line fuses etc. but no luck. [Flagstaff Ultra Light 8528 RSWS 5th wheel]. Any suggestions ? and thank you !
Sorry for butting in on your thread......
2013 Flagstaff Classic Super Lite 8528 RSWS
2007 GMC 2500HD Duramax Diesel
Nobody am perfect, I is trying to are . . .
ready2retire is offline   Reply With Quote
Old 08-05-2014, 12:57 AM   #19
Plain Old Member
ready2retire, first off, welcome to the forum. I see this is your first post. In your case, I would suggest posting your question in this section:
Flagstaff - Forest River Forums
You will get a lot more input from owners of that specific unit.
You can also send a private message to users Herk7769 or OldCoot. They both own Flagstaff / Rockwood fifth wheels and are very knowledgeable of these units and where stuff is at.
You should have 2 Lippert electric slides, and the front wardrobe should be a BAL Accuslide.
Old 08-05-2014, 01:18 AM   #20
Thank you, BigJohnD for directing me to the right spot, and the other info. Much obliged!
slide, slide out
