Old 03-24-2019, 05:36 PM   #1
Slides went out but wont come back in
2016 Cedar Creek 34RL with Hydraulic slides and level up system. I opened up the RV for the 1st time this spring and extended the slides out. I used the remote but dont think that has anything to do with it, When I went to close it up the motor does not run when I hit the switch inside or outside switch. The motor runs when I hit extend.The leveling still works in both directions . Can you extend too far and cause it not to retract? Any help would be appreciated .
P.S. I read a post from yesterday but my motor does run in both directions when I run the levelers up and down.
2014 Ram 2500 4x4
LindaNTom is offline   Reply With Quote
Old 03-24-2019, 07:30 PM   #2
florabama's Avatar
It appears that your jacks/leveling system is working but not the slides. Here is what I would check:
1. The batteries. Are you on shore power and are the batteries fully charged and in good shape?
2. It may be a breaker; when you check may sure you check the micro breakers in the forward storage compartment (behind the king pin). They are very small and can be hard to find the first time you look.
Good luck.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=61
Nights Camped: 2018=25
Nights Camped: 2019=12 | Booked=6
florabama is offline   Reply With Quote
Old 03-25-2019, 08:08 AM   #3
Good luck.
1. I am on shore power and batteries are charged
2. I found the strip with the breakers (3 breakers) and they are ok
Is there a way to bypass the solenoid that reverses the motor to test that?
2014 Ram 2500 4x4
Old 03-25-2019, 08:22 AM   #4
florabama's Avatar
My unit has a large switch next to the hydraulic motor to operate the slides (I think, not sure), check for that if you haven't already.
Old 03-25-2019, 08:28 AM   #5
I had same problem last fall,on solenoid mine has a orange/white wire on one side and a white on other side, reverse these and try the rocker switch, if it slides come in then your control board is bad. New one around $230.00 or they can rebuild yours for around $35.00 I have a 2015 Cedar Creek 36ck.
GaryO is offline   Reply With Quote
Old 03-25-2019, 08:59 AM   #6
Did you try the remote to put the slides back in?
There have been reports here of awnings acting the same after using the remote. I don't have the remote system so I can't verify.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 03-25-2019, 09:08 AM   #7
Jim34RL's Avatar
Here is a very simple solution that may or may not be the problem. There are two switches inside the coach on the panel for the lights, heaters and slide controls. One switch opens and close the slides the other switch turns off the slides so, they wont open or closed. Maybe that switch was turned off by mistake. I would check to see if that switch has been turn off by accident.
I do know that the slides will not work with that switched in the off position.
Please tell us what you find out is the problem so, others can resolve their issue if similar.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 03-25-2019, 09:50 AM   #8
Thanks for the tip Gary. I swapped the wires and the slides came in. So May I ask, when you say control board , do you mean the solenoid the wires are on or where is this control board thats bad and where did you take it to get rebuilt?
2014 Ram 2500 4x4
Old 03-25-2019, 10:23 AM   #9
On my Cedar Creek it is located in front storage above the bus bar with the breakers it has ALTA series written on it.It is app 6"x 6"with alot of wires plugged in to it.I bought a new one then send old back to be repaired,bad relay turn around about a week. American Technology Components 574 262 1258 they have a website great customer service.When changing out take lot of pictures and make all wires where they go
Old 03-25-2019, 10:30 AM   #10
Mark all wires so you know where they go
Old 03-25-2019, 10:41 AM   #11
GaryO Thanks for all your help! This Forum is GREAT
Tom
2014 Ram 2500 4x4
Old 03-25-2019, 10:58 AM   #12
You're welcome
Old 03-25-2019, 11:11 AM   #13
Check to make sure your switch in is the on position, before you operate the slide. (It may take 2 switrches) as others have mentioned.
When battery charge is low, slides get balky. Sometimes they blow fuses. Check the circuit. I am going to find a resetable fuse for my number one circuit which has the slide on it.
Keep your slide rails clean.
ppine is offline   Reply With Quote
Old 03-25-2019, 02:08 PM   #14
The ATC controller is notorious for relay failures. I have had to replace/refurbish twice in three years.
This last time, a couple of months ago, my dealer ordered a new one, and he said ATC were not making these any more and only had 7 left in stock.
I guess next time it fails, will have to make my own relay panel...
Mike and Paula and lil Fwankie Sudz
2016 38EL
2015 F450
IICAPN is offline   Reply With Quote
Old 03-25-2019, 02:28 PM   #15
JPin AZ's Avatar
This happened to me, loose wire at the switch.
JPin AZ is offline   Reply With Quote
Old 03-25-2019, 03:32 PM   #16
I called ATC today and tech support had my model in stock. (RLM-01). H
I am going to send the bad one in for repair and he said it cost $30.00 plus shipping and I will have a spare.
2014 Ram 2500 4x4
slide
