Old 04-27-2019, 12:45 PM   #1
Slides wonít work, level up and awning
Opening our 2016 cedar creek 5th wheel for the season and the slides level up and awning all donít work. Have checked this forum. There is no reset button! Help,
snippitts is offline   Reply With Quote
Old 04-27-2019, 01:05 PM   #2
PPST Wannabe
kenandterry's Avatar
Are you hooked up for electricity or running from your batteries?
All these items need good strong batteries.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 04-27-2019, 01:38 PM   #3
bedubya's Avatar
X2 on the battery. Also check fuses, because even if you are on shore power, those items are 12v.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
Old 04-27-2019, 05:20 PM   #4
After hours of trying everything a fellow camper checked our batteries with a volt meter and 2 batteries were dead. We removed new batteries in our golf cart and put them in the camper and it worked!
Old 04-29-2019, 08:55 PM   #5
I had put my 36ck2 in storage last may and when I went to get it out in Sept, nothing worked either. However my converter had failed. It's not always the batteries.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2015 Chevy 2500HD Crew Cab 4X4 SRW Duramax
Demco AutoSlide 18k
GMRCK25D - Rear Axle Timbren SES Suspension Upgrade
LittleBill is offline   Reply With Quote
Old 04-29-2019, 09:16 PM   #6
Thatís what we thought too, but after the batteries were tested 2 were completely dead
Old 04-30-2019, 09:27 AM   #7
so you left the batteries hooked up in the trailer all winter? if so i can understand why they went dead. there are several small loads that will drain the batteries over time. do you have the option of plugging into an electric source to recharge the batteries while in storage? can you use a small generator to charge them? i had this problem and installed a true battery disconnect switch that removes ALL loads from the batteries while in storage. i can now store the batteries for extended time periods without significant draw on them. others will say pull the batteries out and put them in your garage on a small trickle charger to maintain them.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 04-30-2019, 04:41 PM   #8
I have always taken my batteries for the last 10-15 years. Living in Illinois having no heated garage and no basement I put them in my detached garage on battery misers. Believe that is better than putting them on something that charges continuously or only charging them occasionally (out of sight - out of mine).
Demco AutoSlide 18k
awning, slide
