Old 06-05-2015, 07:49 PM   #1
Smell coming from kitchen sink
36CKTS why is my kitchen sink smelling bad ? Thanks
2014 36CKTS
2014 F350 SW LB
sylviak is offline   Reply With Quote
Old 06-05-2015, 07:51 PM   #2
heavynlori's Avatar
Trap is dry....run some water in sinks
heavynlori is offline   Reply With Quote
Old 06-05-2015, 07:55 PM   #3
We did hot water 😞 still smells
2014 36CKTS
2014 F350 SW LB
Old 06-05-2015, 07:58 PM   #4
heavynlori's Avatar
Hot water smells???
Old 06-05-2015, 08:01 PM   #5
ColoradoRick's Avatar
Is it a rotten egg smell? If so, you may have some stinky water in your lines or water heater. (The best way to fix rotten egg smell is to deodorize the water system with a bleach/water solution.)
If it's coming up out of the sink, do you have the gray valve opened up outside? (Sometimes the smells from the drain will raise up into your camper if you have the valves open.) But the u-traps are supposed to help prevent that.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 06-05-2015, 08:07 PM   #6
BamaBob's Avatar
Put in some Gray Water treatment that should fix it
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-05-2015, 08:10 PM   #7
We just did and I think it's working thanks !
2014 36CKTS
2014 F350 SW LB
Old 06-06-2015, 04:41 AM   #8
ret2006's Avatar
From time to time I would get a smell in the cabinet under the kitchen sink. I replaced the air admittance valve on the top of the sink drain vent. It permits air (vents) to enter when negative pressures develop in the piping system. Closes by gravity to seal the vent terminal at zero differential pressure. Prevents sewer gases from escaping into the cabinet area under the sink. The one on the vent was a cheap black one that must not have sealed properly. Worked for me so far.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 06-06-2015, 09:24 AM   #9
2014 36ckts
2014 f350 sw lb
Old 06-07-2015, 07:07 AM   #10
CCRVOC
Ramblin Recks's Avatar
x2. Worked for me also.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
