Old 08-16-2013, 09:00 AM   #11
Lynkage's Avatar
Looking at your picture, what does it say by the 3.5mm jack on the right? Also wht does it say on the left next to the plastic cover, does it say "Expansion"?
There must be another place where things plug in as I do not see the HDMI inputs/outputs.
A hum usualy means a short to ground. Like a 3.5 mm jack not plugged in all the way or similar.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 08-16-2013, 06:51 PM   #12
We also have a 2013 36CKTS and had the same problem. As an earlier poster said you have to go into the TV setup and turn the TV speakers off. The sound bar will not work if the TV volume is set to variable. When the TV speakers are set to off the TV sound will come through the sound bar.
2008 F350 DRW CC Lariat, Reese 18K
2013 CC 36CKTS
Me and DW
MDCRAB is offline   Reply With Quote
Old 08-17-2013, 03:30 AM   #13
BoatDude's Avatar
The plug on the right says...input 2.....the one covered on the left says....service. there is no hdmi plug on this sound bar. It did work before with radio....now nothing. There must be somthing wrong with the input 2 receptacle.....it does not fit the plug tightly.....but I would think the radio should still play through the sound bar but nothing. I've tried turning off the tv sound....make no difference.
2013 36 CKTS
2014 Ford F350 CC/DRW/PSD/Lariat/
Factory Installed Reese Custom 25K/
ReTrax Pro Cover
BoatDude is offline   Reply With Quote
Old 08-17-2013, 07:39 AM   #14
CCRVOC
Ramblin Recks's Avatar
We have had our 36ckts for 2weeks. I disconnected the sound bar from the radio and tv. I then connected the red and white RCA connectors from tv audio out (red and white) to the sound bar.
In my case, the small "phono"type plug that adapts to a set od red and white RCA plugs did not work with the tv.
Of course right now, the cheap car stereo does not work, but doubt I will ever use it until I replace the whole system.
Reck
Ramblin Recks is offline   Reply With Quote
Old 08-17-2013, 07:58 AM   #15
Lynkage's Avatar
Where does input 1 and input 2 plug into? Can you follow them and tell me where they go? It may also be you need to switch the inputs (Via a switch/button on the front) to get sound from another source.
It is odd that it was working and now it is not. It does seem to be a loose connection by the description. Hard to tell over a fourm.
Lets see where the inputs go............
Shane & Antoinette
Old 08-17-2013, 09:17 AM   #16
BoatDude's Avatar
Sounds like ramblin has the same issue. There are two inputs...one for the tv jack and another for the radio. I think I'll try add use the radio cable for the tv also. See if I can get something to work. The sound bar doesn't change source inputs like it used to. Thanks for trying to help.
2013 36 CKTS
ReTrax Pro Cover
Old 08-17-2013, 09:29 AM   #17
Lynkage's Avatar
Maybe that part is failing. Sorry I could not hep you get it fixed.
Shane & Antoinette
Old 08-18-2013, 05:19 PM   #18
CCRVOC
I went out to the "Creeker" and messed with the tv (Jenson) and sound bar a little. What I found out was the tv sound must be set to "Fixed" and not "Variable" with the tv speakers "Off". Then the sound bar works. But if I turn the tv speakers to"On" the tv auto magically turns the sound to Variable and then the sound bar will not work.
Hmmm, at least I could repeat this process. Not sure why, but it is what it is.
