Old 08-15-2013, 09:14 AM   #1
BoatDude's Avatar
Sound System
We have the 2013 36ckts with sound bar. I would think the tv sound should play through the sound bar.....ours does not. Anyone else get there tv the play through sound bar?
2013 36 CKTS
2014 Ford F350 CC/DRW/PSD/Lariat/
Factory Installed Reese Custom 25K/
ReTrax Pro Cover
BoatDude is offline   Reply With Quote
Old 08-15-2013, 09:39 AM   #2
never assume anything with FR, my Aviator comes with a sony 1000 5.1 surround sound that does not play thru the TV, had to add an optical audio cable. In my 2013 36 ckts it did play thru the TV but I did not have the sound bar, mine was an early build 2013
bob34787 is offline   Reply With Quote
Old 08-15-2013, 10:10 AM   #3
Lynkage's Avatar
Look on the back of the TV to see if you have an audio out.
If so make sure the soundbar is plugged in to it. Or if it is new enough maybe it has an HDMI OUT as well as an HDMI in on the sound bar.
What TV and Soundbar do you have?
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 08-15-2013, 10:21 AM   #4
dretired's Avatar
Our Crusader will play the TV sound thru the AUX with the RCA remote for the sound bar..Watched & listened to the CMA country music show Monday ..really nice !!
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 08-15-2013, 10:32 AM   #5
MC9
My 13 Cedar Creek didn't work right either so, I dismantled the tv and found the wiring screwed up. They are assembled by the amish. What could possibly go wrong with the electronics...
MC9 is offline   Reply With Quote
Old 08-15-2013, 01:41 PM   #6
ret2006's Avatar
You have to turn the speakers on the television off. Go in to the TV audio settings. Then turn on the sound bar (Vizio I would guess) and change the source to the television, because the sound bar may be set to play the radio. Should work then. That is what I did to make it work on my 34 RLSA.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 08-15-2013, 02:08 PM   #7
BoatDude's Avatar
Ill have to inspect the connections.....I tryed the tv thing but sound bar was grayed out and not selectable. Probably the way its connected. We going to camper for the weekend later today...ill double check the tv and plugs. If it works on others it should work on ours.
2013 36 CKTS
ReTrax Pro Cover
Old 08-15-2013, 02:13 PM   #8
Lynkage's Avatar
Keep us posted!! We will get you connected one way or another!!
Shane & Antoinette
Old 08-16-2013, 08:44 AM   #9
BoatDude's Avatar
All the connections look correct. The vizio sound bar plug in loose in the single pin connection...I can jiggle it and it just hums....no sound. It does not work with the radio anymore either. I guess the sound bar went bad. The sub and bar simply hum.....the hdmi goes to dvd player.....I tryed to send pic but it says its crashing.
2013 36 CKTS
ReTrax Pro Cover
Old 08-16-2013, 08:46 AM   #10
BoatDude's Avatar
2013 36 CKTS
ReTrax Pro Cover
