Old 11-29-2013, 10:34 PM   #1
OL Creeker's Avatar
Spare tire
Anybody else have the problem of finding their spare not staying tight to the frame? I have to rewind mine quite often. It comes loose while underway. Anybody come up with a fix?
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 11-30-2013, 05:59 AM   #2
I hadn't noticed, but I also have not looked. Now, I need to go look!
I think I'll wait until after breakfast.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 11-30-2013, 06:05 AM   #3
AquaMan's Avatar
I've never come across or have heard of anyone with this problem. I do know that when I lower my spare and then crank it back into place, I will wiggle it around to find that perfect "nesting" place, and crank a bit more. If yours is continually coming loose, I would say there is a problem with the lift box. I would look to see if there is some type of tension adjustment on this. I've personally have never looked, but worth a shot.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 11-30-2013, 09:00 PM   #4
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
I had the same problem. To think of what would happen when that tire hit the pavement @ 60 mph it would wreck the entire trailer and definitely ruin a really good weekend. Last year I fixed it one day while camping at Pioneer Campground, Laporte PA, using a 3' piece of 3/4" angle, a 2-1/2 T hinge and a few screws, nuts & lock washers. Tools included a hacksaw, drill motor, drill & a few hand tools. I cut a piece of angle long enough to span the hoist brackets, then a couple of 1" long pieces for each side to mount to the hoist brackets then to the angle piece. I then bolted the T hinge to the 3/4" angle, drilled a hole in the hoist rod that aligned w/ the end hole the T hinge then used a lock pin to "lock the hoist rod to the T hinge that was bolted to the 3/4" angle. W/ pin installed hoist rod will not rotate! Problem solved & it took all of 45 minutes to fix.
I'd include photos but it's dark outside, will add them after church tomorrow.
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 11-30-2013, 09:41 PM   #5
Ham Radio since 1970
N9ID's Avatar
Alan, we have had this problem with our 2012 Cedar Creek 36RE. A neighbor noticed the spare tire moving as we were pulling away from a camp site. I tightened it up quickly we were on our way. I do check it before we leave for a trip (added it to our pre-departure check list) and have only had it be loose one other time. This doesn't fix the issue, but it helps it not become a major problem.
Hope this helps,
Mike
Mike & Nena Strong
2013 Cedar Creek 36RE
2012 Chevy Silverado Crew Cab 3500HD Diesel 4WD
Nights camped '14: 51 '15: 134 '16: 149 '17: 171
N9ID is offline   Reply With Quote
Old 12-01-2013, 07:38 AM   #6
Old Member
mikey's Avatar
re: SpareTire
I might be wrong, but this problem seems to be mostly a related to the 2013 Creek. When I have checked it before leaving I find it nice & secure since putting the lock pin on it.
Travel safe & enjoy the journey
Old 12-01-2013, 07:56 AM   #7
RKR
RKR's Avatar
Great thread. Having a CDL and driven trucks for years I thought I had my RV pre-trip inspection down. I never thought about checking the spare mounted on the back.
Thank you for sharing
RKR is offline   Reply With Quote
Old 12-01-2013, 09:35 AM   #8
Old Member
mikey's Avatar
As advertized, here are photos of my spare tire lock mod.
Name:	Aft Mount.jpg
ID:	43322   Click image for larger version
Name:	Fwd Mount.jpg
ID:	43323   Click image for larger version
Name:	Mounting Spare Lock.jpg
ID:	43324   Click image for larger version
Name:	Spare Lock Pin.jpg
ID:	43325   Click image for larger version
Name:	Spare Tire Lock Assy.jpg
Old 12-01-2013, 11:37 AM   #9
Former Full Timer
Duckogram's Avatar
A most elegant mod Mikey.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 12-01-2013, 01:11 PM   #10
rattleNsmoke's Avatar
Looks good. I don't have that problem with my spare since I have to keep it in front storage. My driveway is too steep and the tire would hit if left under The Beast.
rattleNsmoke is offline   Reply With Quote
tire
