Old 07-04-2016, 09:23 AM   #1
DDC
DDC's Avatar
Spare tire Carrier
My 33IK came with the spare tire in the front compartment and I would like to put it somewhere else, I happened to see one of these Click image for larger version
and wonder if anyone has one and how well it works for you and was it relatively easy to install?
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-04-2016, 09:40 AM   #2
Kenny kustom's Avatar
Mines in the basement too.
Going to stick it on the bike rack!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 07-04-2016, 09:45 AM   #3
Spare tire Carrier
I had to find a new location to mount my rear bumper mounted tire because I put a bike rack on back. So I looked at winch style and this hide-a-spare and decided to go with hide a spare and boy I'm glad I did. It was extremely easy to mount and I put it right in front of my single axle. Only downside is checking air pressure. I read people putting a extension on valve and mounting it to outside of frame. Myself I just purchased tpms and mounted it to all my tires. But I highly recommend the hide-a-spare
Ps. There are two different types of mounts. One for open frame and enclosed frame.
DougHeffernan is offline   Reply With Quote
Old 07-04-2016, 05:49 PM   #4
2016 Sabre 36QBOK
Actually ordered the bal slide under the rig thingy today.
Looks ok!
2016 Sabre 36QBOK
Old 07-05-2016, 01:33 AM   #5
2007 WildCat 32QBBS
05CrewDually's Avatar
Looks ok!
2016 Sabre 36QBOK
Ken, if you have a closed in bottom like most, I believe you need to order drop down brackets so the tire clears. I'm not sure if one of the kits come with the brackets or if they're an additional purchase.
What part # did you order?
I been looking into it also in hopes to mount 2 spares. In the end I will probably end up fabricating my own design unless the price is right.
05CrewDually is offline   Reply With Quote
Old 07-05-2016, 08:52 AM   #6
Pice was ok. Under $200 bucks cdn.
I had a credit at the dealer, so I just bought a bunch of stuff.
Don't have any part numbers, but I will mention the drop brackets to him today.
2016 Sabre 36QBOK
Old 07-05-2016, 12:26 PM   #7
DDC
DDC's Avatar
I'd like to know about that to, I know there are different ones for different frames but I seen nothing about additional pieces.
Old 07-05-2016, 01:06 PM   #8
Spare tire Carrier
The I-beam recessed mount Bal 28217 $86 on Amazon is for open beams and underslung bal 28217 $91 on Amazon is for enclosed beams. I would think that drop down bracket would just be longer for enclosed beams ?!?
Old 07-05-2016, 01:20 PM   #9
Have installed 2 of them. Make sure you get the correct model.
If you don't have an enclosed underbelly make sure you have room between the floor joist for the width of the tire if you order the recessed mount.
They do not come with any mounting bolts, or bolts to hold the tire to the carrier.
Mount with the hinge on the drivers side. Used 2 self-tapping bolts to hold the carrier mounts in place and spot welded to the frame. Its a good idea to mount close to the axles as possible because the enclosed underbelly will hang down about 10-12". When mounting the tire, place the valve stem down and on one side or the other of the carrier for easy access to check air pressure. Accessing the tire is not difficult if you can lift 40-50 pounds sitting or bending down. Extending the unit for access to the tire is not difficult. It is basically a larger diameter pipe sliding out of a smaller diameter pipe. Its more difficult to side the carrier back together with the weight of the tire. You may have to bounce while pushing the carrier to close the unit down to rehang the tire.
Reference to the different models available.
NON I-Beam Frames
(C-Frame, Channel, Box, or Z-Frame)
Model 28210
65" to 69" frame width, NON I-Beam Recessed mount
for trailers without underbelly enclosure
Model 28215
68" to 75" frame width, NON I-Beam Recessed mount
Model 28216
68" to 75" frame width, NON I-Beam Underslung mount
for trailers with enclosed underbelly
I-Beam Frames
Model 28217
68" to 75" frame width, I-Beam Recessed mount for
trailers with I-Beam frames without underbelly enclosure
Model 28218
68" to 75" frame width, I-Beam Underslung mount for
Not designed for use on motorhomes or motorized vehicles.
BAL - Innovative Products for the RV Industry
BBQGUY is offline   Reply With Quote
Old 07-05-2016, 04:29 PM   #10
2007 WildCat 32QBBS
Thanks BBQGUY, that's the clarification we needed.
tire
