Old 07-07-2013, 07:40 AM   #1
Speaking of black tank valves...
My black tank valve is very difficult to operate. Both pulling and pushing the handle, I'm afraid the cable is going to break. Anyone else have this issue and found a cure?
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is online now   Reply With Quote
Old 07-07-2013, 08:24 AM   #2
I may have found my own answer. Click on link.
http://www.cessna120-140.org/forum/f...cable_lube.pdf
Old 07-07-2013, 08:47 AM   #3
Dave_Monica's Avatar
You need more oily/greasy food in your diet!
Dave
Old 07-07-2013, 08:56 AM   #4
VinceU's Avatar
Great idea!
Old 07-07-2013, 03:11 PM   #5
Dave
LOL!
Old 07-10-2013, 10:39 AM   #6
mtcreeker's Avatar
Thanks!
Thanks for sharing!
Steve & Carol
2013 Custom 36 CKTS Cedar Creek
mtcreeker is offline   Reply With Quote
Old 07-10-2013, 11:01 AM   #7
avolnek's Avatar
if you would use REM oil... a gun cleaner/oil would work better... WD-40 is a Water Displacement. It doesn't actually have much for lubricating properties... REM oil would stick around and imbed itself... But that is a great idea!
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 07-10-2013, 05:15 PM   #8
Hmmm...I was thinking of a silicon spray. I knew WD-40 wouldn't be a good lubricant. I do have a can or Remington gun oil spray!
Old 07-10-2013, 05:21 PM   #9
Phat Phrog Physician
SabreDoc's Avatar
Try this:
Amazon.com: Camco 40246 RV TST Drain Valve Lube with Coco Oil - 16 oz: Automotive
If it's still sticking then you know it's a cable or handle issue, not the actual valve causing the resistance.
Doc
Ron, Amber & Jordan
2011 RAM 3500 DRW/CC/LB Longhorn 3.73
2014 Sabre 35QSIK-6 Platinum Edition
SabreDoc is offline   Reply With Quote
Old 01-24-2014, 08:12 AM   #10
I have had the same issue on our 2012 CC 34rlsa since we bought it new in June of 2013. I finally was able to get under the unit last week and discovered that they must have gotten Stevie Wonder to run the black tank pull cable. What I did was disconnect the pull cable from the docking station and re-route the cable and now it pulls and pushes much easier. Hope this helps.
mikepizz is offline   Reply With Quote
