Old 02-20-2016, 06:39 AM   #1
TimfmCt's Avatar
Stablizing 2012 29RE
Good morning,
This may be a repeated question but I thought I'd ask a specific question.
I've shortened the front legs as much as possible using concrete pads sacked up under them. I've also shortened the sissor Jack spread as much as I could.
There is still a bit of bounce.
A friend suggested that I also support the midsection of the frame with asjustable jack stands to take weight off the tires.
Is this a recommended thing to do?
TimfmCt
Tim fm Ct
2012 Silverback 29RE
TimfmCt is offline   Reply With Quote
Old 02-20-2016, 06:54 AM   #2
Yes! Youroo!!
Old 02-20-2016, 01:36 PM   #3
TimfmCt's Avatar
Originally Posted by youroo View Post
Yes! Youroo!!
Thanks for ur reply. I'd like to get more info on this kind of stuff. Our Creek is very vey different than our MH>
Tim fm Ct
Old 02-20-2016, 01:43 PM   #4
Ford Idaho's Avatar
Place a board or a block under the stands, then screw them tight to the frame.
Two stands in front of the front axle and two behind the rear axle.
Aluminum Stack Jacks, set of 4 - Camco 44560 - Stabilizing Jacks - Camping World
Amazon may have them for less $...
Old 02-21-2016, 05:55 PM   #5
tkmi's Avatar
Scissor chocks between the wheels, sold st camping world.(stopped mine).
2013 Silverback 33RL
2010 2500 RAM 6.7L
tkmi is offline   Reply With Quote
Old 02-22-2016, 03:31 PM   #6
dieselguy's Avatar
Your motorhome was built alot stouter than your current Silverback frame and flooring wise. All things mentioned above will help, but you may not ever get the solid feel of the motorhome.
dieselguy is offline   Reply With Quote
Old 02-22-2016, 03:37 PM   #7
Pickin' & Campin'
Yes many folks are using a mid frame type of support.
Bottle jacks, adjustable jack stands, scissor jacks (manual & electric) to name a few.
Bear in mind, you will take SOME weight off the tires with this stabilization method but do not try to lift the tires off the ground.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 02-23-2016, 07:29 AM   #8
Why not lift the tires off the ground
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 02-23-2016, 08:16 AM   #9
Who Dares, Wins
doc73's Avatar
Most stabalizer Jack's are just that, stabalizers. They will not hold up the full weight of a trailer. The front legs of a 5er will most likely but the rear / middle Jack's may buckle.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 02-23-2016, 08:29 AM   #10
steelpony5555's Avatar
Shortening up the front jacks and scissor chocks in both sides are about the best you can do... If you get the scissor chocks that will stiffen it up pretty good......
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
