Old 12-12-2015, 08:54 PM   #1
wls
Stackable washer dryer
I bought a used washer dryer set, stackable. With them, I got the brackets to stabilize the washer to the floor. This is a splendide Ariston models. I do not have the instructions for the mounts, but sort of got it figured out, question is, I know they screw down to the floor, but do you mount them to the washer (screw them) before mounting them to the floor?
Another question I have, they show where to drill thru the wall, so I'm going to get a 4" hole saw, but what kind should I use, a bi metal with sort of finer teeth? Thanks
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 12-15-2015, 07:29 PM   #2
I didn't bother with brackets. It's in the closet and not going anywhere.
Use a fine blade for a smoother opening.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
