Old 06-11-2014, 04:35 PM   #1
jaygeo1's Avatar
Standard Bed TV
I was wondering if a forum member is towing a Cedar Creek Silverback 29RE with a standard bed (6 1/2) and no slider? Looking at the 2500HD SRW Duramax. Also considering a 4x4 drivetrain. Are the notches in the front cap adequate? I would appreciate any comments. Thanks.
jaygeo1 is offline   Reply With Quote
Old 06-11-2014, 06:12 PM   #2
I've got a 2013 F250 with a 6 1/2 foot bed and a standard hitch. I've have the 5th wheel at almost a 90 degree angle to the truck. It does fine. The caution is to be careful doing this on uneven ground. Anyway. I did the research ahead of time and I don't think you need a slider for this combination.
Pat & Karen
Seattle, WA
2012 CC Silverback 29RE
2013 Ford F250 Lariat, Crew Cab, Short Bed, Diesel, 4WD
Retired and trying to travel where it's warm.
pengle is offline   Reply With Quote
Old 06-12-2014, 05:44 AM   #3
ret2006's Avatar
I pull my 2014 Cedar Creek 34 RLSA with a standard bed 2011 Silverad HD with a B&W Patriot hitch, no slider. Also pulled two other 5th., wheels prior to the CC. No problems.
I don't want to ever try a 45 degree turn, tight turns put way too much stress on the trailer and tires.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 06-12-2014, 11:35 AM   #4
arpipeliner's Avatar
I do have a slider but have never used it. Only can think of two times I have ever come close to the fuel tank. Within six inches.
One was in a park and a truck was parked where I had to make a tight turn. It was 5:00 AM on Sunday and trying to beat the snow storm out of Michigan. A friend and I was going to travel home in case anything came up.
Other is my drive. The ditches are deep and road not very wide. I have a 18' ft culvert. My solution just got 3 pieces of pipe. 2 are 19' and one 14'. Plan on having over 30' culvert when I get home.
I have put a fifth airborne hitch and it gives u more distance and at least 75% better ride while towing.
Here is my TV 3/4 ton quad cab with short bed and 100 gal fuel tank.
I wouldn't worry about it. Click image for larger version
Name:	ImageUploadedByForest River Forums1402590742.632428.jpg
arpipeliner is offline   Reply With Quote
Old 06-12-2014, 03:59 PM   #5
Do your homework! Measure how much clearance you have at max turn radius. Previous RV was 2011 36ft Keystone Outback with new style cap. Did a 180 degree U turn; cost me $660 in paint and dent removal. My 2015 Silverback 33rl has similar clearance. I chose to keep my slider hitch and ONLY use it in extreme tight turn areas when parking. I believe you will be fine with your rig. Just back very slow and pull forward and then adjust steering and ease back . There is no loss of pride in getting that thing backed in right ! I ignore all non requested backing help even if provided by the campground. Hit something and they are GONE !
Always ask campers to please move vehicles that may be in your turn radius.
Last year at 2 tight campgrounds vehicles were damaged by RV parkers!!
SilverbackMel is offline   Reply With Quote
Old 06-12-2014, 04:34 PM   #6
Not sure if all 29 RE come with an extended hitch. If the one u are looking has the kingpin underneath the camper that would be the only way I be concerned. Like above get measurement or get some one u know that has a short bed to hook up and pull it around. The dealer in WV offered this to someone while I picked up mine.
Name:   ImageUploadedByForest River Forums1402608862.661587.jpg
Old 06-12-2014, 04:47 PM   #7
Good comment. I ordered my 2015 with TrailAir hitch. May make a difference
Old 06-12-2014, 09:51 PM   #8
jackandjoanne's Avatar
You will be fine. I tow a 2014 29 IK with a Sierra 2500 HD 6 1/2 bed no slider. Had concerns too but so far no issues,
Jack and Joanne
Lakeville Pa
2015 GMC 2500 HD
2014 Silverback 29 IK
jackandjoanne is offline   Reply With Quote
Old 06-13-2014, 01:46 PM   #9
I have a 2014 CC29RE and tow with a 2014 Silverado 2500 HD -6l- with 4 wheel drive and a 6 1/2 " box> I also have a R16 hitch.....a good friend who has towed many 5 wheelers said "if you are going with the R16 I would recommend that you go one step further (not much more$$) and get the slider - you might need it sometime" So I got it..have not used it yet....Have been at 90* twice no problem ..Ground was level!!!
Jim in Halifax is offline   Reply With Quote
Old 06-21-2014, 04:53 PM   #10
Get the 3500 instead. About the same price and more load capacity. You'll thank yourself in a few years when you get a bigger trailer.
GOTTOYS is offline   Reply With Quote
bed
