Old 08-22-2016, 09:15 AM   #1
Stuck Black Tank Valve
So now my black tank valve is stuck open in my 2013 36CKTS. Was able to open to drain before leaving, but now I cannot push it in at all. The other valves appears to be working fine.
How hard is it to replace the black tank valve? Supposed I have to drop the bottom lining and should see the tank and valves?
Greg
Truck: 2015 F350 Platinum
Trailer: 2013 Cedar Creek 36CKTS
spawnman is offline   Reply With Quote
Old 08-22-2016, 12:27 PM   #2
Head Rambler
Once you gain access to the valve it isn't much of a job to replace it.
You can either drop the underbelly by removing the trim and screws or you can cut a three sided flap in the underbelly if you can figure out the physical location of the valve and then reseal it with Gorilla tape. If that doesn't bother you.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
black, black tank, tank
