Old 05-30-2016, 06:38 PM   #1
Stuck black water valve
The rear black water drain valve is stuck in the closed position . This is a 2 week old camper . I went to drain the gray water and black water rear tanks today . Gray water was stiff but it was able to drain. Black valve handle will not budge . It is raining pretty steady do I didn't want to get under the trailer . But if any body has suggestions they would be welcome
litespan46 is offline   Reply With Quote
Old 05-30-2016, 08:38 PM   #2
wls
sprayed mine with solvent, then took some pliers and turn it somewhat, loosened up.
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 05-30-2016, 09:43 PM   #3
Stuck valve
Found problem, handle wasn't screwed tight on cable shaft. Tightened it turned handle couple of turns clockwise, was able to pull handle to open drain. Go figure a loose screw . This was the only thing I didn't check on PDI. So far this was the only problem found .
black, black water, water
