Old 01-20-2008, 03:03 PM   #1
powerboatr's Avatar
suburban SF heater 35k btu
for the last two seasons i have run into a few weird shut downs on the furnace
it will run and heat up but once the thermostats says to turn off, it does and then it stays off, until you turn off the heat at the thermostat
then it will re cycle and run fine for another year or so
it also makes tons of air noises versus actual air flow out the vents.
best way i found to get it out of lock out is to remove all power from the heater, then let is sit 10 minutes and bam is all good
so last night when it got to 20f it decided to act up again, so it got cold fast
after reading numerous manuals and some repair site i thank i found the solution.
apparently when the furnace runs for an extened period, like when its COLD as a freezer and the furnace cavity gets HOT the brain goes into lock out.
this morning i removed the stairs and the heater intake grill
and went to work ( with lots of help from the mrs.)
we vacumed and cleaned the dust, amd set out to better "air flow" in the heater chamber.
first off after cleaning, was the sealing of HOT air leaks, around vent hole pre-puncouts and the front cover.
I was very surpised at how much Hot blow by air (not exhaust gasses) was escaping the heat box and recycling back into the fresh air intake, plus heating up the wood flor and associated wiring.
after sealing up the leaks and tying back some close wires, the heater is quieter and has a better flow out the registers
took some afterward pics.
i used alum duct tape on the hot stuff
so far it has run perfectly this morning and afternoon with no more lock outs
ID:	599   Click image for larger version
ID:	600   Click image for larger version
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 01-21-2008, 06:00 PM   #2
powerboatr's Avatar
talked to a suburban rep today
the extra holes are supposed to be blocked and sealed to get maxium efficiency and life from our propane fired heaters.
using just the metal blank off plates is not the best practice, but they know rv builders dont seal em up
so all my lost heat was going right out the exhaust and blowing around the enclosure vice heating the coach
furnace has operated flawlessly now since yesterday after the repairs.
Old 01-21-2008, 06:05 PM   #3
something else to do now.........
thanks!
aintgotnun is offline   Reply With Quote
Old 01-21-2008, 06:35 PM   #4
powerboatr's Avatar
thanks!
looking out for all you WEEKENDERS
really has made a difference
Old 02-15-2008, 05:36 PM   #5
powerboatr's Avatar
its been almost a month now. my propane usage ahs dropped off considerably after closing up all the holes.
we were going through a 30 lb bottle in a few days when the heater had to run to keep us a comfy 70,
now it doesnt run as much nor as long to heat up the coach
Old 02-15-2008, 11:21 PM   #6
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I guess mine will warrant a looky. Thanks.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
cedar creek
