12-21-2015, 08:27 AM
#21
Originally Posted by youroo
They do come in different sizes by different makers but all still have 3/4 TP for install! Your choice on Al/Mag? Youroo!!
Youroo, my pale white gray matter is having difficulty with your "3/4 TP" phrase. Please explain for me.
Thx, Dan
12-21-2015, 08:30 AM
#22
Thx, Dan
3/4" Tapered Pipe Thread! Youroo!!
12-21-2015, 09:13 AM
#23
It is unusual for anode rods to be completely wasted after just 1 year, but it can happen. Water with extreme mineral can cause rapid galvanic exchange, and better that the anode rod takes the hit instead of the water heater rusting out.
I have been using the same anode rod that came in my 2008 unit, and will probably replace it at the end of next year.
Nov 2010:
Dec 2012:
Oct 2014
Nov 2015
12-21-2015, 09:15 AM
#24
I only put soft filtered water in our RVs,,,
And drain WH after every use !!!
The Anode Rods last for years !!!
12-21-2015, 09:34 AM
#25
They week we moved into our home and installed a new water heater, I removed the anode rod immediately. Bacteria tends to grow on the rod and gives the water a sulfer/rotten egg smell. Been in the house 10 yrs and the water heater is still going strong. I'll sacrifice a water heater not to have the smell. As for our campers. I've only had to purchase 1 anode in all the years we've had campers. We are weekend warriors for the most part and they just tend to last longer than we keep the camper. I will replace one when they get to 25%, though.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
12-21-2015, 09:37 AM
#26
AquaMan,,, do you have a water softener ???
12-21-2015, 09:40 AM
#27
They use mag. anode because it goes away rather than the alum. tank! Not for your health. An anode gets used up to prevent corrosion of the WH tank.
12-21-2015, 10:09 AM
#28
Yes I do, which does help to extend the life of the water heater.
12-21-2015, 10:33 AM
#29
Many anode rods available for less than $20.00 on Amazon or other sites.
12-21-2015, 11:00 AM
#30
Thx!
Sent (I think)
12-21-2015, 01:25 PM
#31
If you have an anode you most likely have a steel tank.
My Atwood wh is aluminium and has no anode.
Peace!
Dan & Rita D
12-21-2015, 08:46 PM
#32
Aquaman - the sulfur smell is from anaerobic bacteria that flourish in the presence of iron in the water. You can precipitate the iron before it goes into the tank with fresh air/oxygen and a simple filter, or you can flush/sterilize about every 2 weeks, or you can chlorinate constantly.
Magnesium anodes are best for fresh water systems. They are eaten away by galvanic action which is driven by electrically charged ions. This usually caused by the water impurities but can also be driven by stray electrical currents.
12-22-2015, 08:17 AM
#33
We bought a Spa a few years back,,,
I was really surprised to find that you are not to fill with soft water !!!
They told us that soft water was hard on the plumbing ???
Must be the PH & Hardness is off ???
12-22-2015, 08:37 AM
#34
Who Dares, Wins
I seem to get around 2 or so years until I need a new one.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
12-22-2015, 09:13 AM
#35
It's all about the water we put in our units !!!
We had a TT for about 7 years,,, anode was still @ 3/4 size !!!
12-23-2015, 09:26 AM
#36
After reading this thread, it reminded me that I hadn't checked/changed since I bought unit new 2 years ago. Ordered one from Amazon with a rinse out wand and WOW! Just a stick! White garbage flowed out for about 3 minutes while rinsing. Glad I checked -we leave tomorrow to avoid the full moon!
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
12-23-2015, 09:32 AM
#37
Oh where did it go?
Originally Posted by 97flhtcui
We own a 15 34rl. We full time and took delivery in early February.
I pulled the anode and found it spent in 10 months of use. It may be in everybody's interest to check and flush your water heater while it's out. We have been full timing since 07 and never had a anode wear down that fast. I pull them every 12 months and usually have 1/4 left. FYI
Since it was a factory rod it will go pretty fast, it is designed to save the tank, and with the water getting harder and harder every year this problem will not get better.
It should not really bother you that the rod is worn out that is it's job, and yes if you fulltime you should check you rod and flush your tank at least once per year if not a better idea do it twice.
Hope this helps and Happy Camping and Merry Christmas
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
12-23-2015, 09:20 PM
#38
Ambassador
Got My anode yesterday, bought an extra to have just in case I get surprised.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
12-23-2015, 09:44 PM
#39
Funny, I've not ever had a bad or worn out anode rod in 2 units over 13 years.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
12-23-2015, 09:46 PM
#40
Who Dares, Wins
You need to get out camping more.. [emoji12] [emoji57]
2015 Chevy HD D-Max
