Old 07-05-2015, 08:10 PM   #11
We have a TRC 34750 and it's saved us a couple of times (that we know of) already. Your call as it's your trailer but as has been said earlier when you spend $50K on a rig $300 or $400 to protect your investment seems like money well spent.
Flatlander
2015 Silverback 29IK
2010 Silverado 2500HD LTZ
6.6 Duramax / Allison 1000
Flatlander49 is offline   Reply With Quote
Old 07-06-2015, 03:22 PM   #12
WolfWhistle's Avatar
Progressive actuall calls it an electrical management system, but people insist in calling it a surge protector. Features for the hardwired 30 amp unit.
Features:
High low voltage protection: Whenever source power falls below 104 Volts, or rise above 132 volts the EMS HW30C automatically shuts down power to the RV. Once the AC source rises above 104-volts, or below the 132-volt level the time delay indicator flashes for the preset time and then automatically restores power to RV.
Time delay for A/C Compressor: Whenever source power is interrupted by the source or the EMS, due to a fault condition the built in time delay is activated. There are two settings on the EMS; one is 136 seconds, and the other is 15 seconds. Consult you Air conditioner manual to see if it has a time delay built in, if so use the 15-second delay if not use the 136-second delay.
3 Mode surge protection: This feature provides full surge protection L-N, L-G, and N-G.
Total Joule rating is 1820, response time of <1 nano second.
Surge Indicator: If ever a power surge damages the surge protector circuit within the EMS L-N, or L-G Digital display error code will read E-10. This is your indication that it needs to be replaced.
Reverse polarity protection: If source has a reverse polarity condition, the EMS will not allow power to the RV and the error code will read E1.
Open neutral protection: If the source has an open neutral condition the display will not light, and will not allow power to the RV.
Open ground protection: If source power has an open ground condition the EMS will read an error code of E2 and will not allow power to the RV.
AC Frequency Protection: If source power frequency deviants +/- 9 hertz from 60 cycles per second the EMS will shut down source power, and indicate an E7 or E8 error code on the digital display.
Accidental 220V protection: If 220 volts is detected when plugging into source power the EMS will not allow power to the RV. If this condition occurs while power is applied to the RV, the EMS shuts off power instantly. The display will read the voltage, and the appropriate error code.
Remote information panel: Scrolls continuously all of the power source information, voltage, current, frequency, error codes, and previous errors. Each reading is displayed for 2 seconds.
Previous error code: This feature tells the user why the EMS previously interrupted power to the RV. This is only displayed if an error actually occurs and goes away when power is disconnected to the EMS.
Bypass switch: This switch is located on the remote panel, and allows the user to bypass the computer circuit in the EMS in the event of computer failure, thus allowing source power into the RV. This does not disable the surge protection portion of the EMS.
Modular design Replacement parts are designed for simple plug and play, making repairs extremely user friendly.
Microprocessor controlled: The computer, and remote display are driven by state of the art microprocessors that are programmed with software to drive the entire EMS. Should this software be changed EMS, owners can receive a free upgrade processor with the return of the old.
Dimensions: 5"W x 9 1/2" L x 3 1/4" H
Lifetime Warranty!
The plug in model offers the same level of protection with the display on the ourside unit and bypass is manual. I don't think it offers AC time delay, but not sure of this.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-06-2015, 06:08 PM   #13
cag2515
Send a message via Yahoo to Cag2515
Great info
Features:
Lifetime Warranty!
Thank you for all that great information going to put it to great use once again thank you ever so much your new friend CG
Cag2515 is offline   Reply With Quote
Old 07-08-2015, 05:42 PM   #14
14 CC 38CK's Avatar
I not only have 1 progressive unit for my 38ck but I also carry a back up just in case . You never know when the one you have might quit like mine did last month and yes the life time warranty is well worth it . I sent it to progressive and they repaired the socket that had cracked and we had it back with in a week , but with back up I didn't have to worry .
14 CC 38CK is offline   Reply With Quote
Old 07-09-2015, 06:07 AM   #15
cag2515
Once again I cannot thank all you great people out there for the comebacks on my question about surge protection I have already ordered by progressive ENS HW 50 C and can't wait to install it thank you very much to everybody hope to see you guys out on the road
Old 07-09-2015, 07:45 AM   #16
ret2006's Avatar
This is one of the single best things you will purchase for your RV. Progressive is the best.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 07-09-2015, 07:49 AM   #17
SYE
SYE's Avatar
Do i really need a 50 amp surge protector with my brand new 38 CK Cedar Creek new to this game and getting ready to go on the road thanks for any info
Yes you do, if you take a low voltage hit, it will cost you well over a thousand bucks to replace all the cheap electronics that they install in them.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 07-22-2015, 12:23 AM   #18
Just ordered me the progressive plug and play 50 amp. Better have it and not need it.
Gitiup is offline   Reply With Quote
Old 07-30-2015, 04:20 PM   #19
cag2515
Hi everyone picking up my 38 CK Cedar Creek on Tuesday I was told I do not need a slider fifth wheel for my ram 2500 six and a half foot bed can anybody give me any advice on
Old 07-30-2015, 04:34 PM   #20
Ford Idaho's Avatar
Better to have and not need.
Perhaps an option?
https://www.google.com/#q=sidewinder+rv+hitch
