Old 02-08-2016, 05:37 PM   #1
Global Nomad
Scheinin's Avatar
Surviving the Winter
I just took possession of a 2016 Cedar Creek, 36 CKTS. I am living in it full-time, and will be traveling around the country for the next 5 years. Problem is I live in Maryland and cannot get out of my driveway because of the snow storms. So far no real problems, however they are calling for temperatures down to -7 degrees. I have the Artic Package that says I am protected down to 0 degrees. My question is for those living in their RV full-time in the Northern US and Canada, what do you do?
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 02-09-2016, 08:55 AM   #2
dieselguy's Avatar
You and many others fall prey to the supposed "artic package" advertising, but moving on. Skirting, dual pane glass, 100 - 200# propane tanks, heated water supply hose, supplemental interior ceramic heaters, dehumidifier, taping up or caulking any known holes in the underbelly, insulation between windows and shades, 60 watt light bulb near convenience center, not leaving your dump valves open will get you started for research. You may need to adjust what you call a warm comfortable temperature as well.
dieselguy is offline   Reply With Quote
Old 02-09-2016, 09:05 AM   #3
Winterized I assume. When the roads clear get out of dodge. Head south in the winter, north in the summer.
Old 02-09-2016, 10:26 AM   #4
Global Nomad
Scheinin's Avatar
Winterizing would defeat the purpose of living in your RV full time. I suspect there has to be some full time RV'ers that live in Canada, or northern US. What do they do?
Steven J. Scheinin
2015 RAM 3500 4X4
Old 02-09-2016, 10:43 AM   #5
Best investment I have made was a skirt and the heated water hose so far this winter it has been down to 4F with no problems. I do not have the arctic package. This winter I am in Northern PA
2015 Siera 377FLIK
2014 Ford F350 KR
Molly the new Chihuahua
Cricket the Chihuahua RIP
Steve & Jojo
stevewise is offline   Reply With Quote
Old 02-09-2016, 10:53 AM   #6
OK you ask, Go to Search at the top,put in "Northern Mn.in 385BH Full Time! This is Member Gypsy Family dated 10/19/2012! Read the complete thing,it will answer a LOT of your Q's! Youroo!!
Old 02-09-2016, 09:05 PM   #7
arpipeliner's Avatar
I do it. In New York right now. Very pissed off the job didn't start. I cannot justify having to make camper payments and renting a place. If you have someone that has experience in it. I can do it where you are. Was down there on snow removal.
Personally I would hire someone to move the snow or melt it with a weed burner to get on the road. It can get expensive to stay where it like that. PM if I can help. But there is a huge learning curve here.
arpipeliner is offline   Reply With Quote
winter
