Old 02-24-2015, 09:41 AM   #11
If you were to upgrade, it is not simply an axle swap. You would also need springs, equalizer plate and everything between the frame and the ground. If your going to go that far, you might as well upgrade to disk brakes and 17.5 inch tires and wheels. For the cost involved it might be as cheap to install a complete MorRide suspension package, disk brakes and 17.5 inch tires.
donniedu is offline   Reply With Quote
Old 02-24-2015, 09:42 AM   #12
Campingnut's Avatar
cbari I have the same trailer but with the upgrade and I think it actually rides rough not sure if yours does this but I have a hard time keeping stuff in the cupboard above the appliance garage unless I have the trailer loaded very heavy.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 02-24-2015, 10:55 AM   #13
MC9
I was a little dismayed at the 6K axles on our '13 34RLSA. But, we really wanted that unit. However, it has 5 leaf springs instead of four like our previous SOB. I did have the dealer swap my new Commercial TA's for the Towmax's. So far so good...
MC9 is offline   Reply With Quote
Old 02-24-2015, 11:26 AM   #14
What are the specs on the trailer??? I have a 2013 sandpiper 365 saq with 6k axles. Long story short the springs bent because they put to small of a suspension on it. I now have 7k axles. Much better rid and braking
chiro is offline   Reply With Quote
Old 02-24-2015, 11:38 AM   #15
Campingnut's Avatar
Length 36'8" Dry axle weight 9484lbs GVWR 14085 mine with 7000LBs axles GVWR 15500lbs
Tim and Bev
2015 F-350
Old 02-24-2015, 12:26 PM   #16
Campingnut's Avatar
Here are the stickers on my 34RLSA with the 7000lbs axle upgrade. Not sure what would be on the standard trailer.
ID:	70142   Click image for larger version
Tim and Bev
2015 F-350
Old 02-24-2015, 06:47 PM   #17
30 for RLS a axle replacement
my unit came with 6000 pound axles and e rated tires with a max pressure of 80psi. Blowout 2nd trip out. I felt e rated tires were not strong enough so I wanted to go to it G rated tire but the pressure would be 100 pounds. next problem was the rims were not recommended for that pressure and in order to change the rims to a 100 psi I had to go to 7000 pound axles for the 8 bolt lug pattern. Calls to Forest River and some moaning of my worries and they replaced axles suspension rims and tires including the spare. Cost me 300 for labor but i feel much safer. Happy camper now. Also put tire minder system in.
bigbetty is offline   Reply With Quote
Old 02-24-2015, 09:17 PM   #18
97flhtcui's Avatar
Hi cbari,
I have a 2015 34RL. I have the optional 7k axles. If you plan on going to Elkhart Indiana there is a man name Ron and he owns Recreational Specialties. We had talked about the same thing when I was having a fiberglass rear cap installed to our Cardinal last year. He told me he could put 7k axles that already had springs complete and Goodyear g rated tires and 110 psi wheels for under $3,000
Installed. The piece of mind alone makes it worth it. All you gotta do is blow a E rated tire once then it all makes sense.
Jack
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 02-25-2015, 08:30 PM   #19
Originally Posted by 97flhtcui View Post
Hi cbari,
Jack
Thanks Jack, that is good information to know. If I had known the 7K axles were available as an upgrade when I ordered, I would have gone that route. I'll get in touch with Ron and see what he says.
Carroll
Carroll & Betty Davis
2011 Ford F250 Superduty Powerstroke
cbari is offline   Reply With Quote
Old 02-26-2015, 03:50 AM   #20
ret2006's Avatar
I purchased my early 2014 CC 34 RLSA off the dealer lot. One of the options that sold me on this unit was the G14 Goodyear tires and the 7,000# axles with 8 lug aluminum rims. The tires was what really caught my eye. Option #20-6419 at $2,320.00.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
suspension, upgrade
