Old 02-26-2015, 06:54 AM   #21
X2 on that. I like the windows but the tires and axle upgrade with the Goodyear tires was nice and then when I found out how much more weight I could carry was icing on the cake.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 04-13-2015, 07:22 PM   #22
Originally Posted by bigbetty View Post
my unit came with 6000 pound axles and e rated tires with a max pressure of 80psi. Blowout 2nd trip out. I felt e rated tires were not strong enough so I wanted to go to it G rated tire but the pressure would be 100 pounds. next problem was the rims were not recommended for that pressure and in order to change the rims to a 100 psi I had to go to 7000 pound axles for the 8 bolt lug pattern. Calls to Forest River and some moaning of my worries and they replaced axles suspension rims and tires including the spare. Cost me 300 for labor but i feel much safer. Happy camper now. Also put tire minder system in.
bigbetty, What year is your 34RLSA? I have a 2013 and was told that the 7000 axles and Goodyear tires couldn't be ordered for my unit.
2013 Cedar Creek 34RLSA
2008 F350 Crew Cab 4x4 6.4 diesel
Pullrite SuperGlide
jomyers95 is offline   Reply With Quote
Old 04-13-2015, 07:53 PM   #23
Campingnut's Avatar
I ordered our 2013 with the 7000lbs axels and goodyears from the factory.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 04-13-2015, 08:40 PM   #24
My 34rlsa is a 2012. I am so much happier with having upgraded suspension and tires/ rims. Ride did get a little stiffer but no problems to speak of. Just repacked my wheel bearings today so I no I will be good for the season.also new battery's in my tire minder system.
bigbetty is offline   Reply With Quote
Old 04-14-2015, 02:16 PM   #25
Hi there, can you help me understand how the ride has improved or stiffened? I can't tell any difference in ride quality if my trailer is maxed out to 15.5k or running empty? Do the larger axels get a beefier spring packs? I am just trying to get my head around ride quality when everyone is in the TV and how one can measure this outcome.
SKGCRD is offline   Reply With Quote
Old 11-22-2015, 08:31 AM   #26
dcglovier's Avatar
Suspension Upgrade
I have a 2012 34RLSA with 6000# axles. The springs are flat. Is there any reason not to just change to heaver leaf springs?
dcglovier is offline   Reply With Quote
Old 11-24-2015, 09:15 PM   #27
97flhtcui's Avatar
dcglovier,
If your springs are flat, you should get the trailer weighed at a truck stop that has cat scales. You may be towing overweight.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
suspension, upgrade
