Old 10-08-2013, 10:09 AM   #1
Tailgater problems
Iíve got a 2014 Silverback 33RL, and Iím having a problem trying to get my Dish Tailgater to work though the satellite connection on the trailer. Iíve check the connections and they were loose at the work station but were tight under the TV, no good. I also tried it thru the bedroom sat. connection and cable connection in case they were cross wired. still no good. Iíve call Cedar Creek but they are moving everyone around again. So any suggestions would be appreciated, thanks in advance.
jimmac28 is offline   Reply With Quote
Old 10-08-2013, 10:16 AM   #2
bubbles's Avatar
Have you tried connecting it directly to your receiver bypassing all camper cabling?
Old 10-08-2013, 10:16 AM   #3
Oakman's Avatar
My Silverback has two connections for satellite in the entertainment center. One is for the pre-wired roof mount the other is for a portable satellite dish that goes through the cable connection in the docking station. Be sure you are connecting to the correct one in the entertainment center.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 10-08-2013, 10:22 AM   #4
Yes that's how I get to work, but I have to pull the cable thru a window.
Old 10-08-2013, 10:24 AM   #5
Yes I've check that to, the roof sat is right with the TV antenna and the sat is by it's self
Old 10-08-2013, 10:27 AM   #6
Tailgater Problems! You dont want too go a (Greenbay) Football game! Youroo!!
Old 10-08-2013, 10:41 AM   #7
Oakman's Avatar
Be sure you are using the correct cable for the connection from the wall plate to the dish receiver. I believe RG-6 is required. When I hooked up my tailgater for the first time I used some old coaxial cable I had laying around, it didn't work. I had to make a trip to WalMart to get some RG-6 and voila, it worked. Hope you solve your problem soon.
Bob and Joyce
ATU Local 788
Old 10-08-2013, 10:46 AM   #8
bubbles's Avatar
Whatever port, other than your overhead antenna, you are able receive a good tv signal from the tailgater should function also. You just have to switch the incoming cable from that port to the receiver antenna input.
Old 10-08-2013, 11:21 AM   #9
bubbles's Avatar
One other point. My gray coax that came with my tailgater did not have good connector crimps (made the signal intermittant). Just a thought.
Old 10-08-2013, 11:30 AM   #10
CCRVOC
Ramblin Recks's Avatar
On my CC, the satellite In connections were marked incorrectly. The Bedroom Sat was actually the Living room Sat and vise-versa.
Ramblin Recks is offline   Reply With Quote
