Old 09-11-2014, 10:36 AM   #1
Papi
Papicamper's Avatar
Tank Heater(s) Question
I have belly tank heater(s) in my 36CKTS. Are they in all 3 tanks, just the fresh water tank or what? Thanks for info!
PapiCamper
Cedar Creek 36CKTS
F350 Lariat ("Big Blue")
Papicamper is offline   Reply With Quote
Old 09-11-2014, 11:16 AM   #2
Witch Doctor's Avatar
If you have a tank heater switch, you should have all tanks heated and all elbows at the discharge. That means 12 v pads on each tank and heat wrap at the elbows of your lines. If your plugged in it's great but if your out in the boondocks, it's bad they pull BOO-KOO amps.....
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 09-11-2014, 01:20 PM   #3
You'll have a thermostatically-controlled 65-watt heater pad on each of the tanks. Our Silverback does not have anything on the elbows - not sure if that's the case with the higher end CCs...
2014 Silverback 35QB4
2018 Ram 3500 3-pedal dually
MIFarmer is offline   Reply With Quote
Old 09-11-2014, 01:23 PM   #4
Are you sure they even come on a Rockwood?....
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-11-2014, 01:36 PM   #5
Replying to the OP - sorry for the confusion...
Old 09-11-2014, 02:06 PM   #6
Mddle of the Rd Extremist
MeepMeep's Avatar
Just wonderin' - what would be classified as a higher end CC? do any of them have any "snob" value?
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 09-11-2014, 02:48 PM   #7
They came on our Rockwood Mini Lite !809S - all three tanks & on sewer drain lines.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 09-11-2014, 03:03 PM   #8
Do you not have a Rockwood? They came out standard on both of our Flagstaffs.
Old 09-11-2014, 03:09 PM   #9
Cedar Creek as opposed to Silverback.
Old 09-11-2014, 07:19 PM   #10
MeepMeep's Avatar
Guess I gotta start dressing a little better....who knew?
MCPO (Retired)
Old 09-11-2014, 07:28 PM   #11
Herk7769's Avatar
Tank heaters on the sewer pipes are only installed if the elbow is in a low point or exposed.
I only have 3 pads Gray, Black, and Fresh.
The switch controls a relay that routes 12 volt power to the pads.
HAM CALLSIGN - KC3FFW
Old 09-11-2014, 07:57 PM   #12
Not sure about tank heaters but outlet elbows on all 3 tank drains have heaters on my Rockwood.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 09-12-2014, 03:47 AM   #13
Big Paul, They come standard on the Rockwood/Flagstaff line . You should have I think it is either 12x12 or 14x14 pad on the bottom of the tanks plus as you said your drain lines at the elbow or 45 near the valve.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-12-2014, 03:53 AM   #14
Do not understand, yes I do have a Rockwood as stated above in my eailer post that it came with heat tape and pads. Don't understand your statement?....
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-16-2014, 10:21 AM   #15
Papi
Papicamper's Avatar
Thank you...all
Thanks for info on heaters. Wow...heater on the black tank...now that IS high end! Too bad it doesn't radiate to the toilet seat. LOL BTW, enjoyed CPOs reply too...get out your dress whites to check the tanks!
PapiCamper
Cedar Creek 36CKTS
Old 09-16-2014, 04:34 PM   #16
Herk7769's Avatar
The Rockwood and Flagstaff divisions use similar floorplans and options.
Similar models will have similar plumbing and tank/elbow warmers.
Old 09-16-2014, 05:03 PM   #17
Herk, kinda thought that is what I said..
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-16-2014, 05:24 PM   #18
Dazed & Confused
M&K Hoffman's Avatar
Standard equipment on 2014 models anyway according to brochure page 11.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 09-16-2014, 05:44 PM   #19
They were standard on our 08Flagstaff 831RLSS and our 12Flagstaff 8528RKWS.
Old 09-16-2014, 05:48 PM   #20
Nice looking unit, hope you have safe travels and most of all fun...... You really can not beat the Rockwood/Flagstaff line for the buck. I even see they changed to a different axle. Always improving the line.......
Coachmen M/H
Concord
2018 / 300 DSC
heater, tank
