Originally Posted by Stevemc
If the tank heater is on, the water in the tank works as a conductant to keep the water in the tank above freezing. Wouldn't this conductive action also extend to the water that is in the drain line between the tank and valve? The only freezing problem should be if there is water in the drain line past the shut off valve.
My grey water valve was below the tank with about a four foot piece of schedule 40, had the drain line been schedule 80 the line may not have busted, the valve has thicker walls and it didn’t burst only the drain line. The drain line was touching the frame so that may have caused the drain line to burst. On the new Cedar Creek this May have been changed. My Creek was built in 2014
