Old 02-15-2016, 11:03 AM   #11
A couple of processes: dawn detergent and ice on a summer day works "slick".
Spray lube valve rods where possible.
Or as I do:
Valterra Back Flush Valve $42 on Amazon. Gets everything OUT and you have a view cap to see when it runs clear. EZ directions.
Thetford DRAIN VALVE LUBE: $11.39 on Amazon. Designed to lube the internal rod components.
Lastly NEVER leave black tank drain lines OPEN when on site. Seals dry out and sewer smell is not good with dinner!!
Frequency depends on your RV use. It took longer at winterization to ensure all systems were clear before adding anti freeze. I use very little water and anti freeze in the holding tanks.
SilverbackMel is offline   Reply With Quote
Old 02-15-2016, 11:11 AM   #12
Rest and Relax's Avatar
Originally Posted by VinceU View Post
Shouldn't be that way. Both tanks will have residue build up on tank walls over time. Get into a habit of cleaning the tanks with chemical or water rinse on a regular basis. They will always work. Forget TP draping 6 inches vertically probe to probe, it ain't happening. The tanks contents even dry cause a circuit probe to probe. If allowed to build up.
Easier to prevent than to clear up. Works for me.
I empty and flush my tanks every weekend and take tank monitors do not work but no a big deal I have never had s--- on my floor yet.
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
Old 02-15-2016, 11:14 AM   #13
Left Coast
Buy some lye....let'er rip where you are
Sent from my XT1080 using Tapatalk
Old 02-15-2016, 11:43 AM   #14
Oaklevel's Avatar
Never had a tank sensor work properly never worried about it ...... Just after the years have a good idea how long the tank takes to fill........ the trailers of our past did not have them............
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 02-15-2016, 02:41 PM   #15
VinceU's Avatar
Originally Posted by dieselguy View Post
VineU ... give us your steps on tank care ... there several thousand of us out here that just don't seem to have the technique down.
I built my own lance for black and an separately for grey, both have ball valves for local control. Lances were tested on the lawn to provide low volume high velocity jet stream. They will thrust like a jet engine and strike nearby surfaces very hard, just what's needed. Forgotten the orifice size where ideal, maybe 3/32-Click image for larger version
Name:	ImageUploadedByForest River Forums1455568210.889503.jpg
Name:	ImageUploadedByForest River Forums1455568384.419836.jpg
The grey tank washer is similar but uses hose to snake down tank vac vent below bath tank in Georgetown.
Both jets must be lowered 1-2 inches at a time and rotate full circle. The key is concentrate in direction of sensors for good scrub.
Of course the level systems are indicators, not gauges i.e.:approx levels, still nice to know "almost empty or full".
tank
