Old 02-14-2016, 07:52 PM   #1
Tank Sensors
I hate to ask, have a 2016 33IK have been out for little over a month. Both the gray and bath tank sensors are reading 2/3 full. Never had this issue in our previous Wildcat. Anyone else having problems. We have not moved so I have not had a chance to do a proper cleaning using dish soap and a good drive. I do use a drop in for the gray and bath tanks made for soaps and greases, have used this also in previous Rv. Black tank is good
Rich5117 is online now   Reply With Quote
Old 02-14-2016, 08:07 PM   #2
Rest and Relax's Avatar
I find tank sensors never work properly after the first use.
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
Old 02-14-2016, 08:08 PM   #3
Left Coast
X2
Old 02-14-2016, 08:13 PM   #4
Mark and Linda's Avatar
Mine work good sometime and other times I wonder. When the water backs up in the tub, time to dump the gray water....
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 02-14-2016, 08:15 PM   #5
wowzer's Avatar
Your mad if you put any validity in tank sensors.
Jim and Sherri Brown
2013 Silverado 2500 6.6 DuraMax
2012 Sabre 34REQS6
wowzer is offline   Reply With Quote
Old 02-15-2016, 05:34 AM   #6
I generally put on a HAZ MAT suit and mask with 6 layer rubber gloves. Go
open the end valve and if sprayed to look like "Linus", pretty much dump time! Leave spewed poop to dry to mark my territory.
Same suit comes in handy when washing the dreaded sewer hose or " brown snake".
Every time this happens, wife says: " told you not to buy an RV". 😄.
One WOULD THINK the mfgr could buy reliable parts! But WHY?! Money is in the aftermarket sales.
My suggestion: non leakable top cap, long "stick" like farmers used on tractors many, many years ago to check the oil. When poop hits the near full line, ut ohhhhh! Honey, I am really into this game. Can you get it this time?! 😘
Worth a shot! ( perhaps a poor choice of words )
My other suggestion, which will NOT BE FOLLOWED, are glass tanks hidden behind view panels; look, see; DUMP 👍.
Ok, enough of this CRAP. Go have a fun day and just leave the caps off! Never a problem.
Another issue resolved! Yes!!
SilverbackMel is offline   Reply With Quote
Old 02-15-2016, 07:48 AM   #7
dieselguy's Avatar
Although you apparently had exceptional luck with your Wildcat sensors ... welcome to the real world of stock RV tank sensors. Like the Pirate Code, your sensors are really just guidelines. (Pirates of the Carribean movies) The sensors are just little nodes implanted in the end of your holding tank. If any little thing sticks to them ... they read positive to that level. You'll learn to gauge how long you can go and signs of near full such as the stool burping when near full once you use your fiver for a while. There are accurate alternate sensor systems out there that adhere to the side of your tanks and generally use existing wires. You'll have to drop a couple of belly panels to install.
dieselguy is offline   Reply With Quote
Old 02-15-2016, 08:03 AM   #8
VinceU's Avatar
Shouldn't be that way. Both tanks will have residue build up on tank walls over time. Get into a habit of cleaning the tanks with chemical or water rinse on a regular basis. They will always work. Forget TP draping 6 inches vertically probe to probe, it ain't happening. The tanks contents even dry cause a circuit probe to probe. If allowed to build up.
Easier to prevent than to clear up. Works for me.
Old 02-15-2016, 08:40 AM   #9
dieselguy's Avatar
VineU ... give us your steps on tank care ... there several thousand of us out here that just don't seem to have the technique down.
Old 02-15-2016, 08:56 AM   #10
Even if they're operating perfectly, they suck.
Using a 30 gallon freshwater tank as an example.
If it reads empty you could be empty, or have 9.9 gallons.
9 gallons is enough for a shower and to flush the crapper, empty not so much.
If it reads 1/3 you could have 10 gallons or 19.9 gallons.
If it reads 2/3 you could have 20 gallons or maybe 29?
And that takes for granted they installed the sensors accurately which they never do. Black and gray tanks are even more inaccurate because they never calculate the placement to allow for the sloped bottom of the tank. On a 30 gallon black tank they usually have the 1/3 sensor located so it lights up at about the first flush.
Install this. https://www.garnetinstruments.com/rv-shop/products/
It works every time.
Mr Havercamp is offline   Reply With Quote
tank
