Old 05-28-2014, 09:50 AM   #1
Tank valves, what's the secret????
Good day all!
Earlier this year my wife and I pick up a 2011 CC 34RLSA.
We bought it home this past weekend to load up items that we have stored for our past pull trailer, as we are taking it out this weekend for it's maiden voyage!
After cleaning and loading I thought I would go over a few things and make sure they are in working order...
Think things are ok other that the fans in the main living area and bedroom, think I broke them by not turning them off properly...
They still work but now make a noise :-(.
I them moved on to try to dump some grey water which we had in the tanks from de-wintering it and cleaning...
When pulling any of the valves they don't seem to come out much!
Maybe 3/4 of an inch...
We called the people we bought it from and they said they never had any issues with them.
Please advise if we are doing something wrong? (Really would like to go out this week end and be able to use the Bathroom!!!!)
Thanks!
Truck 2009 GMC 2500 HD,D/A,Ext.Cab,SB,air bags, lift kit, flow gate, etc.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
Camping Day's: 2012:25,2013:27,2014:38,2015:38
Little John is offline   Reply With Quote
Old 05-28-2014, 09:54 AM   #2
Batts-toy's Avatar
What are your tank level indicators showing?
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 05-28-2014, 10:25 AM   #3
Levels are still read empty but the fresh was full and now reads 3/4 due to us using water to test the heater, add chem. to the toilet and do some cleaning...
That's why I had tried the drain valves and noticed both greys and even the black only pull out about 3/4 to an inch...
Old 05-28-2014, 10:29 AM   #4
Ret E-9 Anchor-clanker
donanddona's Avatar
Doesn't sit well with me. I would get my lubricant out and spray the stems (if you can get to them) while working them back and forth. Mt forward tanks required a slot to be cut in the membrane to access the valves. I lube mine spring and fall as a minimum.
donanddona is offline   Reply With Quote
Old 05-28-2014, 10:47 AM   #5
Batts-toy's Avatar
Oh, OK now I understand read your first post wrong. The gate valves should open a distance slightly more than the pipe size (3" pipe 3 to 3.5" stroke) but I guess you already knew that. If lubing the stems don't work, I can only suggest (with empty tanks) disassembling the valves (not difficult to do) inspect and look for something blocking the valve stroke then clear the blockage if it can't be cleared replace them. It is odd that they both have the same problem at the same time though, did you stroke them up and down using some force? perhaps the rubber seals are dried out if the camper has been setting for some time.
Old 05-28-2014, 10:55 AM   #6
DDC
DDC's Avatar
I'm hesitant to say this but will anyway, how hard are you pulling? All three having the same problem at the same time is pretty far out there, I think you need to put more effort into pulling the handles.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is online now   Reply With Quote
Old 05-28-2014, 11:06 AM   #7
Thanks guys, will head out later today and pick up some "Valve Lube" for the tanks and maybe if the weather gods are with us this weekend will look at pulling off a panel on the underside and see "What's up"!
I will also try pulling a little harder as DDC suggested but at being 6'2" and 260 lbs, I didn't want to pull the panel off!
Old 05-28-2014, 11:19 AM   #8
extremebike's Avatar
There is stuff made from coconut oil that I put in the tanks to lubricate the valves at the beginning of each season.seems to work.
http://www.amazon.ca/Camco-40246-Dra.../dp/B000EDSSG6
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 05-28-2014, 11:25 AM   #9
dcheatwood's Avatar
And just to make sure, since your gauge is reading empty, make sure they are not already pulled open by pushing all the way closed. Sure you know this but covering all the basics.
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 05-28-2014, 11:38 PM   #10
That was my thought too! When I picked up my RV, the PDI left all three valves fully OPEN. I didn't get around to checking them until 2 days later. At a glance, they looked fine but then I realized they were all open instead of closed!
F-350 Dually
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
tank, valve
