Old 10-13-2018, 08:58 PM   #1
CampinGpa's Avatar
Tankless hot water heater
When winterizing a tankless instant hot water heater if you leave the valves in same position antifreeze should go through the tankless hot water heater Right. Thank you for your help We have a 2018 Cedar Creek Hathaway 34RL2
CampinGpa is offline   Reply With Quote
Old 10-13-2018, 09:32 PM   #2
BessieHunter's Avatar
If your pumping antifreeze through the system and have antifreeze coming out the hot water faucet, then yes the water heater had antifreeze in it.
BessieHunter is online now   Reply With Quote
Old 10-13-2018, 09:47 PM   #3
2018 Dynaquest 38TS
Yes leave the valves in the same position.
DR Quest is offline   Reply With Quote
Old 10-13-2018, 10:28 PM   #4
CampinGpa's Avatar
Thank you all very much that's what I was thinking we upgraded from a travel trailer to our Cedar Creek wasn't sure about this water heater but once we got it figured out it works quite nice...……………….. BessieHunter nice Fifth wheel Thank you all
Old 10-15-2018, 09:25 AM   #5
Gsykora's Avatar
We've got a CC36CK2 (similar to your 34RL) with a tankless water heater. Is there a drain plug on the tankless system?
George & Nancy, Allen, Texas
2015 F350 CC, DRW, LB, Platinum Edition, 14,000GVWR
2018 Cedar Creek 36CK2, 40ft 5in.
Gsykora is offline   Reply With Quote
Old 10-15-2018, 08:45 PM   #6
CampinGpa's Avatar
No not that I have seen because its tankless so I would not thank that there would be a drain plug.. Nice looking fifth wheel. thanks for the response
Old 10-15-2018, 11:20 PM   #7
I called the manufacturer. Two ways to do it, either works. Don't touch the bypass valves just run antifreeze through the system. There is a drain on the back of the water heater but the wall is in the way and you can't get to it. That would be the other way. I just run ant-freeze through my system. Has worked for the last two Winters.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 10-16-2018, 09:15 AM   #8
CampinGpa's Avatar
Thank you. That is what I thought too. but it looks like I have to do it again I forgot to blow out the city water connection.
heater, hot water, tank, tankless, water, water heater
