Old 01-01-2015, 10:52 AM   #11
kinzoo's Avatar
You need the batteries installed...
kinzoo is offline   Reply With Quote
Old 01-01-2015, 12:22 PM   #12
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
Temperory Power
How about taking jumper cables and connecting to the truck battery and to the battery cables on the rig?? Frank
Eaglelover is offline   Reply With Quote
Old 01-01-2015, 12:38 PM   #13
kinzoo's Avatar
That may work also,
Thanks Frank
Old 01-01-2015, 12:41 PM   #14
I'd think that would work but the OP stated he has isolated and insulated his battery cables (IOW wrapped them in tape?). So probably too much trouble. But a good flashlight would work.
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
WeRCreekers is offline   Reply With Quote
Old 01-01-2015, 04:03 PM   #15
arice24814's Avatar
Mine is in storage right now, i use the truck to power the slides, and the onboard for the interior light(also recharges the units batts .leave it running) works great. If i just try to use coach batteries to open it up for inspections and just general cks it drains them quick. But i have to have the batteries installed to and switched on for the lights. only runs the Slides
arice24814 is offline   Reply With Quote
Old 01-01-2015, 07:10 PM   #16
using the slides w/o batteries
A master tech told me the main cause of slide failure is caused by operation with low power. IOW, low or no batteries. The converter doesn't provide enough power. They may move, but they are being damaged. Like running the A/C on only 20 amps.
rvguy66 is offline   Reply With Quote
Old 01-01-2015, 09:08 PM   #17
Campingnut's Avatar
Any time you use any electric motor with lower than recommended voltage you run the risk of damaging it.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 01-29-2015, 11:27 AM   #18
dieselguy's Avatar
For those of you who when in storage operate slides solely off your pigtail connected to the truck ... you're putting an insane current draw upon a 14 gage (maybe 12 gage) charging wire on your tow vehicle. That's why it is s-l-o-w moving and lights dim down. It doesn't do your pump motor any good. I'd bet you could barely touch the TV charging wire with a bare hand after opening the slides.
dieselguy is offline   Reply With Quote
5th wheel, power, tow vehicle, wheel
