Old 12-31-2014, 03:04 PM   #1
Temporarily Powering a 5th Wheel from a tow vehicle.
In the winter I remove both batteries from my 36CKTS.
I thought for the few winter inspections I make at the storage facility I would just plug the tow power cable from the 5th wheel into my tow vehicle to provide power for lighting only. When I attempted this the interior lights didn't come on. The battery disconnect switch was in the ON position. I have not had time (and it's too cold) to trouble shoot.
Shouldn't what I tried work?
The tow vehicle charges the batteries successfully when towing.
Wlasota is offline   Reply With Quote
Old 12-31-2014, 03:08 PM   #2
fonzie's Avatar
Did you leave your tow vehicle running when trying the lights? Maybe it needs to run....also are all your 12 volts cables connected together at the battery box eg: all positives together and all negatives together?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 12-31-2014, 03:47 PM   #3
Dave_Monica's Avatar
Another thing to check is if you have the relay or fuse installed in the truck to provide 12V power at the 7 way plug. Easiest way is to check at the truck's plug for 12V power between pin 4 and pin 1 (ground) with the truck running.
Dave
Old 12-31-2014, 04:21 PM   #4
Thanks for the suggestions. The battery cables for both batteries are isolated (insulated) during storage.
Old 12-31-2014, 05:49 PM   #5
Cant do it! Charge line only supplies minimal current to recharge the house battery while under way. Leaving it connected without a battery in place does not complete the circuit for lights. Take a battery with you and if nothing else using jumper cables connect it. Take it home with you when your done
donniedu is offline   Reply With Quote
Old 12-31-2014, 07:10 PM   #6
J_KHawthorne's Avatar
Guess it must depend on the unit. I store my battery on a trickle charger in the garage over the "winter" here while at our winter home in southern Arizona. The trailer is at a storage unit without power. Lights and slides operate when plugged into the 7 pin off the truck. Slides are a little slower maybe, but they work!
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 26,890; Nights camped; lost count!
J_KHawthorne is offline   Reply With Quote
Old 12-31-2014, 07:13 PM   #7
Crusadernoob's Avatar
Ours will power up also, truck must be running but that is how we winterized, off the truck 7 pin.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37
Crusadernoob is offline   Reply With Quote
Old 12-31-2014, 09:02 PM   #8
Should it work - yes.
Sounds like a wire is not connected, possibly a ground wire from the pigtail into the rig.
It should provide basic lights, might operate the slides on a good day, and some leveling systems. The size wire for the "charge" line in a tow vehicle is too small to provide much (even for charging really) power to the camper. Again it should work just be careful with the power use.
Using a volt meter check the power at the battery terminals - should be 12 Volts. If not check power at the plug.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 01-01-2015, 11:31 AM   #9
OK, I think the OP said his batteries are removed from the coach and are in his garage back home. In my CC, the battery has to be installed (or at least in the circuit) for this to work. The 12V lights are operated from the battery. Plugging in my truck without the battery installed will not power the lights. It will however, slowly charge the battery if it is installed. So, at least for me, donniedu is right. Some of the responders in this thread are not CC owners and the OP is.
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
WeRCreekers is offline   Reply With Quote
Old 01-01-2015, 11:47 AM   #10
Campingnut's Avatar
I also need a battery installed for anything to work in my unit.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 01-01-2015, 11:52 AM   #11
kinzoo's Avatar
You need the batteries installed...
kinzoo is offline   Reply With Quote
Old 01-01-2015, 01:22 PM   #12
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
Temperory Power
How about taking jumper cables and connecting to the truck battery and to the battery cables on the rig?? Frank
Eaglelover is offline   Reply With Quote
Old 01-01-2015, 01:38 PM   #13
kinzoo's Avatar
That may work also,
Thanks Frank
Old 01-01-2015, 01:41 PM   #14
I'd think that would work but the OP stated he has isolated and insulated his battery cables (IOW wrapped them in tape?). So probably too much trouble. But a good flashlight would work.
Skip & Susan Orrell
Hurst, Texas
Old 01-01-2015, 05:03 PM   #15
arice24814's Avatar
Mine is in storage right now, i use the truck to power the slides, and the onboard for the interior light(also recharges the units batts .leave it running) works great. If i just try to use coach batteries to open it up for inspections and just general cks it drains them quick. But i have to have the batteries installed to and switched on for the lights. only runs the Slides
arice24814 is offline   Reply With Quote
Old 01-01-2015, 08:10 PM   #16
using the slides w/o batteries
A master tech told me the main cause of slide failure is caused by operation with low power. IOW, low or no batteries. The converter doesn't provide enough power. They may move, but they are being damaged. Like running the A/C on only 20 amps.
rvguy66 is offline   Reply With Quote
Old 01-01-2015, 10:08 PM   #17
Campingnut's Avatar
Any time you use any electric motor with lower than recommended voltage you run the risk of damaging it.
Tim and Bev
2015 F-350
Old 01-29-2015, 12:27 PM   #18
dieselguy's Avatar
For those of you who when in storage operate slides solely off your pigtail connected to the truck ... you're putting an insane current draw upon a 14 gage (maybe 12 gage) charging wire on your tow vehicle. That's why it is s-l-o-w moving and lights dim down. It doesn't do your pump motor any good. I'd bet you could barely touch the TV charging wire with a bare hand after opening the slides.
dieselguy is offline   Reply With Quote
5th wheel, power, tow vehicle, wheel
